tnk.Originally Posted by MatthijsNL
buth I select a motherboart with build in powersupply it only need 12 volt
and the I have redesign a DC-DC converter
You were searching for a relaiable power supply I read.
I'm building this one.
http://www.mygizmos.net/frames/hardw...wersupply.html
4u2n looks like your carpc is going to be great...can't wait to see it finishedGood work
Bons dias phluid, PORTUGALNice to see some portuguese people around here too
Greetings from Portugal :) Where the sun always shine bright...well I think.. :D
CarPC Project - Multimedia eXperience
[...................................] - 0 % Complete (Still on planning stage)
Yes is a long way, when i want to make 99% ( there will always be 1% to changes after it finish)Originally Posted by Kusanagi_Kei
bye the way the powersupple is nearly finish an the plan change because the shutdown and a volt monitor is build inthe PCB buth it only has a size at 2" * 3"![]()
To tell you Im not a portuguese, I come form Denmark
Pre install of the hd,dvd and main board in the carbon case
Finish of the PCB for the power dc-dc convert with shutdown and volt monitor
That case is perfect! Is it just carbon fibre and aluminum, or is there more to it?
No I miss one thing, I have used glue to build itOriginally Posted by noodles
6 piece of carbon 1 to each side
12 piece of alu profile
