Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 77
Thread: MP3 car in SEAT Ibiza
  1. #31
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    At last I come to the end of the tunnel an can see the light
    I have a system works on my table
    All the plan, are finish for this time (but I have more Idea for the future)
    I only need the PCB and a P-FET for the power control
    And I got it in the next week
    A awful thing happen last week, a scooter has drive in the side of my car,
    Monday I gone drive to get repair
    Thy say et take 1-2 week to finish the work
    So when I got it back I want to install the System
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
  2. #32
    May 2004
    Denmark
    The prototype of the shutdown controller is finish and all work perfect
    It can control a current around 30 Amp.
    Function
    1. Tank battery automatic switch to tank battery when main power loos, this controlled by to relay
    2. to control the main power to the dc-dc converter and power on and off the pc, I use a PIC controller coming from PICAXE and it only cost 2 $ and very easy to program.
    I use standard car relay with homemade connector, maybe not nice but it wrok
    The next step is to make the final layout with 2-3 more function where I need a bigger PIC with more I/O pin.
    Ditail at 4u2n.dk
    Here
  3. #33
    Oct 2003
    Looks great.
    Where are you going to mount your radio ?
  4. #34
    May 2004
    Denmark
    Now the screen is mounte in the dash
    to make it finish instal I need a dag to connect all to wire
    It a hard job to hide all the wire
    Ditail at 4u2n.dk
    Here
  5. #35
    Oct 2003
    Looks absolutely great !
    The only question I have is: where did you put your radio ?????
  6. #36
    May 2004
    Denmark
    Quote Originally Posted by Wizardtm
    The plan is to hide the radio insite the dash,
    then make a remote cable to the from radio to the forntpanel of the radio
    If it's posibel to move cable from the radio to the sun vison, the front panel will be instald there..
    Photo will comming when it install...
    Ditail at 4u2n.dk
    Here
  7. #37
    Sep 2005
    Quote Originally Posted by 4u2n
    ??? how do you want use your CD in the radio when you hude it insite the dash... ????
  8. #38
    May 2004
    Denmark
    Quote Originally Posted by _rex_
    When I destined to hide the radio inside the dash, it was a goodbye to the cd
    I have a cd/dvd drive in the computer to use
    The only thing I use the radio to is
    1. A part of the power control system
    2. as amp. For the pc
    3. and to uses as radio
    Ditail at 4u2n.dk
    Here
  9. #39
    Sep 2005
    How do you use the radio for power control ????
  10. #40
    May 2004
    Denmark
    I have made power control system to be sure, I not com to my car and the battery is empty
    Function
    The switch block with pin 1,2,3,4 and x
    It can only one connection form 1,2,3,4 to x at the time
    1 to x = always power
    2 to x = power when the radio switch to CD aux function
    3 to x = power when the radio is ON
    4 to x = power when you start the car..
    If you use the 1 to x function, the controller sound every 5 sec, if you press reset the sound stop , it’s because the system can dry you battery in this function ( if you forget it )
    This 4 function give you opportunity have power on the system all possible way
    Ditail at 4u2n.dk
    Here
  1. User help to design MP3 car CD radios
    By MP3Design in forum General MP3Car Discussion
    Last Post: 03-20-2006, 05:57 PM
  2. How do you resume an mp3 after turning off/on your car?
    By fatman in forum General Hardware Discussion
    Last Post: 03-20-2006, 03:19 AM
  3. Creative Labs may have the MP3 car solution...
    By GinoRP in forum Input Devices
    Last Post: 12-21-2003, 03:24 PM
  4. Palm interfacing with car mp3 players?
    By Kajo in forum General Hardware Discussion
    Last Post: 04-26-2001, 05:25 AM
  5. Help needed please.. about MP3 car player.. txt
    By Jackson Ho in forum General Hardware Discussion
    Last Post: 01-04-2000, 09:44 AM
