This is sweet! I love the dash job!
- System
7'' Xenarc Touchscreen
Epia M 10000, 512MB, 30GB,
Earthmate GPS, D-Link Extreme G,
Gyro Mouse/ Keyboard.
I am using Media Engine with a skin designed by SharkWeb
-- Added on an Rockford 351M with a Infinity 10" DVC
Thanks for all of the sweet installs to help boil my passion.
Cory
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
is that last picture a pic of your trunk?
if so, are those subs?
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
Originally Posted by acura cl
It is the passenger (their is pockets on both sides, the left one holds jack / tools and changer and an amp in my car) side pocket in the trunk. The speakers you see are the Bose sub that comes installed from the factory.
I have not had a problem with them interfering with the computer
Cory
- System
Xenarc 7" Touchscreen, EPIA M 1Ghz , 512 MB, 30 GB, D-Link G wireless, Delorme Earthmate GPS, Gyro Keyboard / Mouse
- Install Thread
http://www.mp3car.com/vbulletin/show-off-your-project/28456-1998-audi-a6-near-completion.html
very sweet setup! i plan on doing this myself in similar areas in my SC400...nice work on the xenarc mounting!
Thanks, many hours of sanding and painting
- System
- Install Thread
http://www.mp3car.com/vbulletin/showthread.php?t=28456
Nice install, the dash looks really good.
Couple of questions, how are you using the stock radio, are you connecting the output from the computer to the headunit? If so what are you using to achieve this?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Are you using an auxialliary input convertor to get the audio into your head unit?Originally Posted by Quattro-A4
Something like one of these? http://www.logjamelectronics.com/auxinpconv.html
I am currently using a Clarion FM modualor to connect the pc to the stock deck. However, I am seriously looking into changing it to use the aux port (the cd changer is currently attached to it) I wanted to see how much I would use the changer after the install. I can sum up my changer usage in one word......"never."Originally Posted by Quattro-A4
The car pc is not as loud as before and the deck seem to go into a safe volume-ish mode so i need to turn the volume up on the deck to crank it. Other wise in normal volume no need. It would also sound a bit cleaner too. I tell people who have listened to it and they call me crazy when I say that. The bose system sounds good but lacking in bass but I solved that by adding a 10 DVC Infinity to the system and really turning the bass down and letting the sub fill that area.
When I moved the stock radio all i had to do was (cut the back of the glovebox) extent the ground wire a bit to still be connected. No other wire was cut not even the hazzard lights, which are accessable to the driver. You need to know where the are though.
Cory
- System
- Install Thread
Wow nice install you got there! Think it was your install that gave those people at Audi the idea to standard equip the new A6 with an MMI.![]()
Why is it drug addicts and computer afficionados are both called users?
Currently : Audi A6 - no install
Second install : VW Passat '97 CarPC
First install : '87 Audi 80 CarPC
