Small one of a CF NSX, only $12,000. For the kit.
http://webspace.utexas.edu/amaiam/cfnsx.jpg
I personally think carbon fiber can look good in a vehicle as decoration, however what i was saying about the screen mount that the shape of it is what is screwy. Not the fact that it is carbon fibre (although it looks like people dislike carbon fiber or maybe it is that they dislike your carbon fiber)
All in all a great install.
now your next stpe is to convert the whole dash to the carbon fibre look
looks awesome. all u guys give me great ideas:
darkhalo, great install. I'm new to this but I have to admit you've done a great jobA Honda S2000 has an interior that isn't suitable for any kind of material or drastic install...but you've done a superb work
Muy bien
Greetings from Portugal :) Where the sun always shine bright...well I think.. :D
CarPC Project - Multimedia eXperience
[...................................] - 0 % Complete (Still on planning stage)
What was the power module (inverter) that you had in the trunk? Thanks for aiding my research![]()
Im not sure what the brand of the inverter is but its not that great... it creates alot of noise which then gets fed back into the amp.. but i guess that how all inverters are..Originally Posted by mgars
Does anyone know if sine wave inverters make noise also?
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
Nice car and install are those Infinity speakers?
If you ground the Inverter or the case of the PC to a common ground that your stereo and amps use the noise should clear. I had the same problem it was anoying.
My 2 cents
Laz
I got a question I dont see here...were you able to install the screen where the stock headunit is? or is there no room? I'm lookin for a dash and center console for my mid engine 2 seater sports car, which the cockpit of your car looks to be perfect...
My first screen was a lilliput inside of a indash inclosure form digitalww.com but i wasn't able to use it because there wasn't enough room for me to shift gears.Originally Posted by NightFireTuning
So i had mastergrade.net build me a custom enclosure that would meld into the dash.
Just to make sure... there was nothing behind where the screen is now.![]()
S2000 Carputer
Yeah those are infinity Kappa 60.5 component speakers.Originally Posted by Aksor
Right now i have the a 4gauge cable connecting to the chassis.. going to a spliter thingy that gives ground to my amp and my inverter..
The only thing i have not grounded is the computer. Im going to try that next.. if that doesn't work then im going to buy one of those power noise filters...
IF that doesn't work then ill just build mastero's 4.5 powersupply...
S2000 Carputer
