Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Range Rover - reworked install
  1. #11
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Wow, that's very clean and good looking!
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  2. #12
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    did you have any problems with the griffin powermate ?
    my powermate is driving me mad ! at this stage only useful for the funky blue light !
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
  3. #13
    Low Bitrate vladilen's Avatar
    May 2003
    Quote Originally Posted by wkolodny
    Do you have a link to a manual for that keyboard encoder? It looks pretty useful. A schematic of how you wired your switches would be terrific too if you could.
    They don't have a digital manual, it's just a double sided xerox that comes with the controller.There is not much to wiring the controller. From the switch, one wire goes to the ground on the PCB of the keyboard encoder, and the other goes to any of the other attachment points. I have a single wire from the ground going to one common line on all switches. The NO line then is connected to one of the other connections to generate a keystroke.
    where did you pry from? The rubber part or where the knob attaches to the base? Or both? Oh and can you still use the push and twist functions with the new knob?
    I don't recall exactly how I opened it. It has been some time ago. It is a total pain to do. Just take a screwdriver to anything that looks like a seam. Yes, it does keep both push and rotate functionality when removed from the case.
  4. #14
    May 2003
    Quote Originally Posted by SAScooby
    Initially, yes. I had to go into System Properties/Hardware/Device Manager, find the generic HID device and manually point it at the griffin driver. After that it worked fine.
  1. Range Rover Epia Install
    By vladilen in forum Show off your project
    Last Post: 03-05-2006, 09:20 PM
  2. Feedback needed for new Range Rover install
    By ratchtjaw in forum General Hardware Discussion
    Last Post: 12-11-2005, 11:33 AM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 03:37 PM
  4. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 03:03 PM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 08:10 AM
