Results 1 to 10 of 12
Thread: 2002 Sunfire, Oldschool ghetto rig
    Jun 2003
    Mobile, AL
    2002 Sunfire, Oldschool ghetto rig, HD44780 LCD
    My 262mhz Cyrix MII carpc.
    HD44780 LCD screen, 6gb hard drive, Windows 2000, USB keypad, Netgear USB 802.11b, plays songs, switches playlists like a cd changer, what more do you need?
    OKay, it's ghetto as crap.
    The pictures attached are:
    -My new/ used 2002 Sunfire
    -USB wifi adapter with parabolic ALUMINUM FOIL antenna
    -Old box installation in my Bronco II
    -New Installation Photo; Temporary box mount for my LCD, using a USB keypad
    http://phillip.darktech.org/mp3box/mp3box.htm if you want to see full specs
    -Phillip
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    Did you have any problems in the Bronco II from the bass tube being pointed at the CPU?
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
    Jun 2003
    Mobile, AL
    no, no problem at all. Actually the vent was pointed at the PC, but it was only 8" and 250 watts...
    -Phillip
    Jul 2004
    There you go. So much for excess vibration!
    May 2004
    Northridge CA
    oh shoot!! thats the same inverter i have cept its 350 watt. but for some reason it wont power my 120 watt PSU!!!
    did you mod it in anyway?
    new fuses etc?
    i really want to use my old pc in my car
    May 2004
    Michigan
    What prog are you using to play mp3's?
    Nice install...it doesn't matter if it's ghetto.
    By the way, are you a member of j-body.org? If not, you should check it out. I'm about to put together my system in a 2002 sunfire. Keep up the good work!
    Jun 2003
    Mobile, AL
    Nope....... just a 400 watt inverter. I think each outlet can only handle 200 because there is a fuse for each one. I could be wrong. My pc only draws around 60 watts. I don't know why it wouldn't power your psu. Does it even try to run?
    -Phillip
    Jun 2003
    Mobile, AL
    not a member of jbody, but I'll check it out.
    Here's what I'm using now:
    Winamp 2.9
    plugins: winamp keycontroller, song Resumer, Playlist changer
    -Phillip
    May 2004
    Northridge CA
    Quote Originally Posted by Talldude4evr
    yea it does run. i myplaystion 2 runs fine. however right wheni plug in my CPU the red light comes on and it shuts off. ive tried it just by itself too and the same thing happens. i think i heard somewhere thatyou need to modify PSUs to use with an inverter but im not sure.
    the PSU does work though it works fine with my house outlets.
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Quote Originally Posted by dannn
    Probably a noisy inverter. Line noise will prevent the PSU from allowing the computer to fire up. That's probably the mod you heard about: removing the filter circuit to allow it to ignore line noise (which is a dangerous thing to do, from the PSU's standpoint).
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
  1. What's with the sudden flood of newbs?
    By ShinkunoNamida in forum Off Topic
    Last Post: 03-29-2007, 01:43 PM
