Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: 1999 Honda Accord - Carputer - 7" Lilli/GPS/MP3/DVD/more
  1. #11
    Jun 2000
    NYC
    Quote Originally Posted by SAScooby
    the only thing I can say is put your left hand rims on the left hand side of the car and the right hand rims on the right hand side of your car
    huh??
  2. #12
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    check out your rims front to back and side to side, are they "pointing" in the same direction ? on the drivers side you have both a L and R rim,
    Honda designed them to "face" or "rotate" in a certain direction, look at the spokes on a rim, some of them lean to the left, the next rim will lean to the right if you follow my angle, they were designed for some or other reason as left and right handed rims, and if a manufacturer is going to do this, as it must have cost a fortune, they must have had a special reason to do it
    the rim should also be marked with a L or R somewhere on the lip
    from what I remember when I owned a civic with similiar rims, the spokes should not "dig" into the ground when going forward rather the opposite way around
    your rims have probably been switched at a service or in that prang you mention.
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
  3. #13
    Jun 2000
    NYC
    I appreciate the advice, I'll look into it. However, please realize that these are aftermarket rims made by Enkeii, not Honda. How are supposed to rotate them?
  4. #14
    Feb 2004
    they look pretty much like the stock ones I had, but have a look at your car on the side !
    the front rim and the rear rim are going in different directions, the front "spokes" are in a different direction to the rear "spokes" any good wheel and tyre shop will take the tyre off the rim and swop it around side to side, while still keeping the tyre direction constant, I would be curious to know if the other side has the same problem.
    if it doesnt bother you then no sweat, just thought I would mention it
  5. #15
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Yes, alloys are primarily for performance-enhancing. I take it having handed alloys allows for more efficient brake cooling perhaps....?
  6. #16
    Feb 2004
    NYC
    Dang, u people sees everything.
  7. #17
    Jun 2000
    NYC
    Back to the carputer fellas!
  8. #18
    Jul 2004
    no.va.
    you need to swap the rear driver tire with either passenger front or rear wheel. i'm sure what you have right now is a byproduct of tire rotation gone wrong (appearance-wise)
  9. #19
    Maximum Bitrate riddle14's Avatar
    Aug 2003
    TN
    sweet setup, can't wait to see the gps mount and your on/off switch, ohh and i do see what they are saying about your rims. no big deal but just for cosmetic reasons you might want to look in to that. question, is this the car you had 13k of damage to? sweet ride!!
    "I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
    By "ToneRiddle"
  10. #20
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    gps mount
    Here is how you should run the gps receiver- run it under the rubber frame, around into the trunk.
    DICE Los Angeles
  1. Honda accord 1988
    By GoatMaster in forum Show off your project
    Last Post: 07-12-2004, 09:18 AM
  2. 91 honda accord install
    By mp3mike05 in forum Show off your project
    Last Post: 06-18-2004, 03:33 PM
  3. Replies: 11
    Last Post: 04-27-2004, 07:47 PM
  4. 99 Honda Accord
    By shane1234 in forum Show off your project
    Last Post: 10-17-2003, 09:04 PM
  5. 1994 Honda Accord CD Changer In to Aux In?
    By dynamike in forum General Hardware Discussion
    Last Post: 01-16-2002, 04:17 AM
