Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 106
Thread: My M3 Convertable Install
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Well, after doing my install in my laguna this was my second chance to get things right.
    First of all the items listed below are installed at the present time.
    Hardware
    Opus 150w
    Xenarc 700TSV
    Epia M10000 (with custom bios)
    20 Gig 2 1/2 Laptop Drive (going to upgrade when needed)
    512MB DDR
    Mircosoft MN-710 54Mbs Wifi
    16 x DVD Rom (going to upgrade)
    D-Link Radio
    Fortuna Serial GPS
    I-Bus Interface
    Mini USB keyboard
    4 Port USB 2.0 Powered Hub
    Software
    Windows XP Pro
    Mediacar (with custom skins)
    WinDVD
    Destinator 2 (SDK version)
    Tons of MP3's
    First of all when I bought the car it had a Kenwood 920 satnav unit it, so after removing this and selling it on ebay I was ready to start my install.
    The first thing I needed was to find a box to stick a motherboard in. I wanted it to go where the kenwood 10 disc changer went in the boot. After searching everywhere I found a plastic box that fitted just right. I bought it from www.cpc.co.uk for about £17. I then bought a M10000 motherboard. I was thinking of getting the new MII 12000 epia board, but I needed two serial ports and that only had one. After a bit of cutting and chopping I ended up with the epia board, i-bus interface and my harddrive all mounted in the case nice.. O + a blue neon light for good measure. I also mounted a USB port on the side of the case, this is used for attaching a usb pen or harddrive to for exchanging data.
    sadly I couldnt fit the opus in, so thats just stuck to the boot with velcro for now. I dont think I will any problems with heat on the opus as its got quite alot of room there. I then had another hole to fill. I decided to mount a dvd rom as well, this was where the kenwood satnav dvd unit was. I still need to fill the holes in or get a replacement side carpet bit for it.. you will see what I mean later.
    Thats the boot stuff done. I took 5v rail from the opus and a 4m USB 2.0 lead up the side of the car to the front. I used the 5v to power the hub at the front, which inturn connects to my keyboard, wifi and touchscreen.
    The wifi is just stuck down with velco, I may move this to inside the piller if theres room at a later date.
    I have attached a usb keyboard in the glovebox.
    The Xenarc screen was stripped down and I fabricated a BMW lookalike housing for it.
    It took me a while to find somewhere to mount the GPS unit, as its a convertable the rear shelf just isnt a option. Then I found somewhere.. under the rear headrest
    This is out of the way and I get good reception now.
    I wired up the dlink direct to my car aerial, it improved the signal no end, its just not as good as a stock headunit, shame really.
    To control it all, I use the touchscreen and keyboard, but the steering wheel controls were wasted so I bought a I-Bus interface from germany.
    This connects directly to the plug that goes in a stock bmw cd changer. I then hunted around for ages.. and ages.. and ages.. finally found the software that I needed to map the steering wheel controls to mediacar. It works awesome makes the whole carputer thing worth while. :-)
    Thats about it for now. I have afew things to perfect, like skins finishing and stuff. but heres a couple of ones I've done so far, ones for day and the others are for night. You might of seen them before somewhere !
    and for night time.. it matchs the colour of the dials :-)
    thats about it for now... here is the finished look so far, you will notice a gap round the dvdrom, this isnt a bad cut job, its where the satnav dvd unit was installed before, I'm going to fill, replace this bit soon.
    The carputer and dvdrom drive.
    This is the amp powering everything.
    and finished off.
    some speakers.
    and the end product :-)
    Let me know if you want anything answering or if you have any ideas how I can improve the install...
    [update]
    I have just altered my motherboard bios to start up with a BMW logo instead of the epia one :-) looks more stock this way
    cheers
    CdRsKuLL
    Whistle Tip pimpJ's Avatar
    Metro, TX
    dang, that's sexy
    Low Bitrate PHiLiSO's Avatar
    Oct 2003
    detroit
    very nice!!!!!!!
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    You sir. Are riding pimp.
    Computer:
    COMPLETE SYSTEM OVERHAUL!!!!!!
    STAY TUNED IN THE UPCOMING WEEKS!
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Very nice
    Shame that the UK's now headed towards being the wettest month of the year right now....
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Wow! Sweeeet! Good job in the clean installl.
    Aug 2004
    ver very nice
    how are you running sound from the carputer to your amp an so such. im trying to find a good way of doing this without needing a head unit.
    awesome setup... giving my wicked idea's
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    I love it ! just beautiful..but why the dvdrom in the back..if u want to watch a dvd or listen to a cd, you dnt want to stop on the highway...are considering anything to take care of that ..or u just dont care?
    DICE Los Angeles
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by paradox
    ver very nice
    If I were to guess I would assume like everyone else that uses a amp rather than HU. Sound Card > Amp > Speakers. Use a RCA -> Stereo miniplug adapter and plug the inputs from the amp directly to any sound card.
    VERY nice install by the way. How is the GPS reception with the top up? It's a cloth top, right?
    Super Moderator xBrady's Avatar
    USA
    WOW. That is nice!! One of the nicest/cleanest installs I have seen. Nice work!
    Installed.
    -GPSSecure- - GPS Tracking
  1. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  2. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  3. Carputer install
    By H3nrY in forum Newbie
    Last Post: 07-25-2004, 10:45 AM
  4. Lilliput 619GL-70NP Touchkit XP Home Install
    By Windchsr in forum LCD/Display
    Last Post: 04-25-2004, 08:23 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
