Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 90
Thread: MKIV VW Jetta Install v2.0
  1. #61
    Sep 2005
    Looking awesome
  2. #62
    Newbie Alvatune's Avatar
    Feb 2006
    Cal
    Hi, I am new here.
    Would any of you give me direction in installing the audio part? I know that its routing is from PC audio ->3.5mm/RCA converter->amplifier->speakers
    but what kind of RCA converter should I buy? the one that splits into two? is it enough? or is there one that splits into four RCA output, and then I plug each one of them to the amplifier? I am having confusion for this part and hopefully you guys can give me a hand on this... Thank you!
  3. #63
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by Alvatune
    Hi, I am new here.
    Depends on how many channels you have on your sound card and amp. For most people just use a two channel (front - left/right) and plug one set of RCAs into the amp.
    For two channel to a amp the installation would be similiar to below except for excluding part 4 and replacing part 5 with the amplifier.
    For more examples check out my pc -> car audio thread
  4. #64
    Feb 2006
    Cal
    Unhappy My onboard audio card is only 2 channels
    Since my onboard audio card is only 2 channels, i will only need one 3.5mm/RCA converter......i think it is the cheapest way to get my speakers to work...
    Alternative way...more expensive but better sound performance....is to buy a HU with AUX in from the PC....but i am so poor....
    Thank you for the info...
  5. #65
    May 2001
    USA
    When you say "alternative" what do you mean? Alternative to what, using a stand alone amplifer? If so, a head unit will most likely not get you better sound performance, just convienience. Those little amps crammed inside a headunit are definitely a compromise when compared to larger stand-alone power amps. I'm not saying there are no good headunits or that it will sound horrible but just that it's typically the other way around for sound performance.
  6. #66
    May 2001
    USA
    Quote Originally Posted by skippy911
    Here is what I used to rip apart my jetta. http://forums.vwvortex.com/zerothread?id=958556
    You can find my worklog here, I have most of the cables run and am working on the pc now. My brother is building a case for the screen for the dash so ill post pics when it is done. Hopefully tonight.
    Jetta 99.5 mkiv
    Thanks a lot for posting that. That's the same thread that I refered to for disassembly. I swear I got asked weekly by MKIV owners in PMs on how to take apart the dash. I couldn't find that exact thread but am glad you fouind it!
  7. #67
    Feb 2006
    Cal
    I've done it!!!
    Thank you for your reply and suggestions!!
    I finally made up my mind and placed my bid on Ebay...got a HU (Alpine) for $150. Hopefully, it will produce better quality of sound than before....other than convienience...I know that I won't get the best quality but I am satisfied for what i have.....maybe I will upgrade it later...
  8. #68
    Registered User SysTronics's Avatar
    May 2006
    Chicago
    Face Plate
    Great install, I just bought a VW Jetta myself, and was actually planning on doing the same thing. I was wondering, how did u get a face plate to fit the console/dash?
  9. #69
    Newbie DriverFound's Avatar
    Jul 2005
    Colorado
    I'm working on the install in my Jetta right now...
    I removed the stock stereo (monsoon) and cupholders (indash type not the center console type) and the 7 inch xenarc fit in there (the screen itself not the whole case for it).
    I took the screen itself out of the case, trimmed down the sides of the front part of the case. As you can see in the pic, it just took a little off each side and the screen itself still fits.
    And just so I feel better... it's in a completely different phase than this now...past this too (being painted/wet sanded now), but that pic looks SOOO bad lol.
  10. #70
    Mar 2005
    I've got an mk4 radio cage that has the Xenarc case molded into it.....It needs to be slightly resanded and repainted, but that's it! PM me if you want details.
  1. 03 VW Jetta GLS Black Box?
    By XtReMaTriX in forum Off Topic
    Last Post: 08-29-2008, 02:44 AM
  2. 1997 VW Jetta GLS Install
    By SiGmA_X in forum Show off your project
    Last Post: 08-22-2005, 05:36 AM
  3. Replies: 2
    Last Post: 05-21-2004, 12:50 AM
  4. Replies: 6
    Last Post: 04-02-2004, 04:01 PM
  5. EPIA 800 in a VW Jetta 1.8 TURBO
    By samc in forum Show off your project
    Last Post: 10-27-2003, 07:18 AM
