Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 90
Thread: MKIV VW Jetta Install v2.0
  1. #71
    FLAC ppgt94's Avatar
    May 2001
    USA
    Looking good, DriverFound! This is almost exactly how mine was done. The only think different is I left a small place underneath the LCD case for the slot-load slim-line DVD/CDRW to fit into. Thank you so much for posting these images. It should take some of the mystery out for some of those considering doing this. I unfortunately never took any of the construction.
    BTW, that logo on the right that says "XENARC" is just a sticker and comes off easily with a fingernail. I find removing it really cleans up the install and makes it look more OEM.
  2. #72
    Jun 2005
    Kent, England
    i'm about to do my dash in my golf that way too.
    i'm using a LinITX 7"
    got all the materials just gotta find the time
  3. #73
    Nov 2005
    tag
  4. #74
    Newbie FREEDOM79's Avatar
    May 2006
    Geensboro
    Hello there friends
    I am about to start my toy in my Jetta, is first time doing this I don’t know to much about computers
    I love everything OEM in my car I really love that VW skin.
    How to set that up?
    Is something that comes with the hardware you have installed, or is some kind of software? (downloadable)
    Appreciate for your help from now!!!
  5. #75
    May 2001
    USA
    *Update*
    Installed a Optima yellow top deep-cycle battery in trunk. Now I can finally leave the CarPC on Standby for extended periods without worrying about starting the car. Aside from near-instant on/off, it's one step closer to the wifi intrusion camera I've had in mind.
    To go with that, I replaced/upgraded the computer in the JettaPC. I got great deal ($45) on an "older" box on ebay. Some of new specs if anyone's interested;
    Intel 815E / PIII 866 / 512MB / AGP ATI Radeon. The new mobo leaves room for upto a 1.13GHz upgrade, which I've seen go for around $20. Doesn't sound like much with todays newer CPU's but more than enough for a carputer. Just for the record, I found my first 266 was able to do everything I do now (MP3, DivX/DVD, GPS, Wifi), less some winamp viz's. The lower power consumption and heat output is a plus, too.
    Also modded the new case with variable speed "blow-hole" fan for improved cooling.
    The next planned addition is a infrared wide angle backup camera.
    Just for the ****s and giggles I'll probably add pics of the updated setup later.
  6. #76
    Jun 2006
    Gainesville, FL
    Looks awesome, I can't wait until I start my project on my IV Golf. How much did you pay for your entire system, I am debating if I should stay with my stock amp and speakers.
  7. #77
    May 2001
    USA
    Quote Originally Posted by ReaperKK
    Just off the top of my head. These prices are what I remember paying. I'm sure current prices are different.
    * IBM Netvista A40p - $45, ebay (local pick-up)
    * 60GB HDD - $80
    * 7" Widescreen VGA LCD Touchscreen - $450
    * 150w Opus DC-DC ATX power supply with startup/shutdown controller - $130
    * TurtleBeach Santa Cruz soundcard - Salvaged from a another PC. (Retail $45)
    * USB 2.0 PCI card - Salvaged (Retail $25)
    * USB 2.0 Powered Hub - $20
    * GPS Reciever - $85
    * Wifi card + 5.5dB external antenna - $70
    * Gyro Wireless Keyboard/Mouse - $90
    * Cables, Wiring, Adapters - $150
    * Software - $200
    * Labor - Lots of time.
    * Set of new component speakers - $300
    * 4-Channel amp - $180 (used, local)
    * 2- Channal amp + 10" sub - $250 (used, local)
    Parts are always changing and I didn't aquire all of them at once. Good luck with your Golf.
  8. #78
    Jun 2006
    hi im a new user and i was wondering if any one can help me out with some info that i need.first of i want to know how to get the software installed on the car(roadrunner)vw.because i have a vw golf and im plannig on doing the same to my car.thanks
  9. #79
    May 2001
    USA
    Quote Originally Posted by haro
    Can someone delete or redirect this post above?
  10. #80
    Aug 2006
    How did you make the dash bezel??? Fiberglass?? I would like to integrate a CD/DVD drive into the console as well, but this is the only place I have seen one?
  1. 03 VW Jetta GLS Black Box?
    By XtReMaTriX in forum Off Topic
    Last Post: 08-29-2008, 01:44 AM
  2. 1997 VW Jetta GLS Install
    By SiGmA_X in forum Show off your project
    Last Post: 08-22-2005, 04:36 AM
  3. Replies: 2
    Last Post: 05-20-2004, 11:50 PM
  4. Replies: 6
    Last Post: 04-02-2004, 03:01 PM
  5. EPIA 800 in a VW Jetta 1.8 TURBO
    By samc in forum Show off your project
    Last Post: 10-27-2003, 06:18 AM
