Page 10 of 22 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 216
Thread: 2004 350z install
  1. #91
    Nov 2003
    Victoria, Australia
    Mike,
    You have done well mate, very well indeed. Does the fin interfer at all with the GPS signal. And finally on the GPS, have you done anything to the GPS housing to water proof it?
    I am waiting for the most important part of my install to arrive, my car I just got word it arrives tomorrow so I am like a child the night before xmas.
    Lilliput is ordered, PC is fully configured, fingers ready for some hard core Bondo sessions.
    Cheers,
    Fatman
  2. #92
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    Hello. Very nice looking setup. I had a quick question -- who makes/where do I get a USB mount like you have your wireless adapter plugged into? It looks like some kind of panel-mount device. I am interested in using one possibly for my car PC but also maybe for my MAME cabinet.
    Thanks!
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
  3. #93
    Constant Bitrate leemik's Avatar
    Aug 2004
    MA
    @fattybigboy
    the sharkfin itself seems pretty waterproof.. I put some silicone where the wire goes out the back though.. So far so good and I've been through some pretty nasty rain and sleet storms and I spray at car wash time and it's fine....
    @gork
    The Linksys USB network adapter comes with that mount in the box.
    --mike
  4. #94
    Illinois
    where did you get that reset button? I need one too cause sometimes windows will totally freeze and i need to get out and unplug the power supply.
    Im assuming its an always closed switch and only goes open when pressed right?
  5. #95
    Aug 2004
    MA
    bulgin vandal switch:
    http://www.frozencpu.com/ele-70.html
  6. #96
    Illinois
    was it a flush fit in your cig adapter, or did you need to modify?
  7. #97
    Aug 2004
    MA
    Not perfectly flush.. it sticks up about 3/8" above the lip of the cig lighter.. but i bet if you wanted to you could make it perfectly flush (by not using the included washer)... but it didn't matter to me.. I just wanted it sturdy and the little door on my cig lighter port to close properly..
    I had to cut the metal terminals on the switch shorter and disconnect power to the cig lighter (don't forget to do this or you could short your system ) -- I learned the hard way lol
    --mike
  8. #98
    Illinois
    Quote Originally Posted by leemik
    --mike
    HAHAHAH, ill remember that. Just to verify, the switch is an ON/OFF switch right? So when you press it in, the computer is on and stay ons, and when you press it again computer turns off?
    And do yo have any heating/ ventaltion problems. From the pics, it seems like that an awfully small spot, much like how mine is when I lower my floorboard. I wanna buy a mat for my trunk, but that would mean keeping the floorboard flat which gives the compute the same amount of room as yours seems to have.
    Have you run into any problems and do you have any more pics showing how much space is in there?
    I see this pic here and it seems the the rear as open space, but is that how it normally is, or when you put everything together, is that space covered too?
  9. #99
    Aug 2004
    MA
    The switch functions just like the reset switch on your home computer.. When Windows is not cooperating, I press and release to reset.. computer reboots and that's it..it should work fine as an on off switch too..
    I haven't had any ventilation problems but it is very tight.. there's maybe one inch of headroom above the CPU heatsink(after cutting away the top of the box... see post #1, pic#1).. On the back, see where the over hang is on that top panel? well another panel attaches to the edge of that and comes down at an angle.. so there's maybe about 1/2 inch on top and 2 inches on bottom--pretty much flush with the cables sticking out..
    The VIA CPU runs very cool though.. much cooler than P4's and Athlons.. lower speed VIA CPU's don't even come with cpu fans.. just a heat sink.. It's one of the reasons why I chose this mobo (size and power consumption were factors too).. When you think about it.. ventilation is probably still better than your typical laptop.
    --mike
  10. #100
    Apr 2005
    great setup! im about to undertake a similar project. im using an existing P3 Mobo i have to do all this. im thinkingof putting the dvd drive in the passenger mailslot and the cpu/HDD in the factory BOSE location if it will fin in there becuase i can add a fan to the bose lid becuase it is already vented what do you think?
  1. 2004 Seat Leon - Costum install
    By guvi in forum Show off your project
    Last Post: 01-17-2008, 05:05 PM
  2. need tips for 2004 accord sedan install
    By keghead in forum General MP3Car Discussion
    Last Post: 07-07-2006, 05:48 PM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  4. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  5. 2004 Altima install
    By DJKhan85 in forum Show off your project
    Last Post: 07-21-2004, 11:32 AM
