How did you connect your hfm-8 to your computer? Did you just solder on a 3.5 mm stereo connector? I have the same mic and can't decide if it would be workwhile to solder or rather to just use an adapter (if there is one).
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
I used an adapter. They are easily found at Radio Shack..
thanks
Are your AC and heat controls now?!?!![]()
Huh? They are right there in the pic... I put in an EATC.
I first want to say your truck looks amazing. I have a question in reguards to what you called minor work, the over head console and the hvac controls. How much did it cost you to do this project?
I have been looking around and priceing out the parts you used and don't know if I am geting hosed or not. Also I am thinking about putting my radar detector built into the console any ideas on that
Thanks. Cost was minimal.. I'd say under $100 for both the EATC and the OHC. Got all the parts from a junk yard.. The EATC I would say was easier but took longer because of the wiring.. The overhead console I had to remove the entire headliner and do some cutting so was a bit nerve racking..
Dead picture links fixed per request.. I accidentally erased all the text from my first post and have no idea what it said before so sorry about that!
Great looking install! I really like the center console. I have a 98 Explorer and am thinking about swapping consoles. Do you have any measurements on the one you picked up? Was it an '03 as well? Thanks for the info!
