Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: finished project 56k death to you
  1. #11
    New York
    install looks great. gotta say, the lilliput basically looks like it belong there.
  2. #12
    Low Bitrate microbionic's Avatar
    Aug 2004
    medina,ohio
    Quote Originally Posted by ppgt94
    Well done! That looks really good. What's next?
    A subwoofer, gps, radio, and engine management (obdII )
    Quote Originally Posted by dbzeag
    damn, another protege!! Sweet install, dude! I have some questions, though.
    Where did you get a glove box that is flat like that? Every side of my box has curves and bumps everywhere so i can't attach a motherboard to it.
    How did you take off your center console?
    Great install, dude.
    If that’s the case we have different glove boxes but I doubt it. I attached it to the back of the box, there was just enough room, for the mini ITX and then I cut out the hump on the right hand side to make room for connectors
    The center bezel comes out by pulling on the underside of the top airvents, point them down grasp the bezel, PULL firmly … hope you don’t break any tabs….
    CarPuter ProgressO meterO
    [+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
    visit me on the web at
    http://gozips.uakron.edu/~cmk23/
  3. #13
    Constant Bitrate Avalerion's Avatar
    Jun 2004
    Hamilton, NJ
    Go Protege!
    Question: How did you pull off the front bezel where you mounted the screen into? I don't want to crack anything when I try it. I'm going to be doing something similar.
  4. #14
    Aug 2004
    medina,ohio
    Quote Originally Posted by Avalerion
    Go Protege!
    just pull from under the vents, it will come off, then disconect the hvac system cables from behind the glovebox, and above the brake pedal... continue pulling
  5. #15
    Cleveland, OH
    And you are in Akron? I am in Cleveland. I might have to take you out for a drink for that!
  6. #16
    Aug 2004
    medina,ohio
    im bout an hour south of cleveland, i chill up in coventry alot. near the case western campus
  7. #17
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    what is the palm used for -- looks like it is linked or conected to the amp
  8. #18
    Aug 2004
    medina,ohio
    Quote Originally Posted by lawrence
    i used the pocket pc to make sure i wired everything together correctly, it was playing an episode of the family guy.
  9. #19
    FLAC ppgt94's Avatar
    May 2001
    USA
    Testing audio?
  10. #20
    Oct 2003
    bummer i was hoping you would say you were seting up the crossover or something to the same
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  2. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  3. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  4. project media mustang is finished
    By kram in forum Show off your project
    Last Post: 02-10-2004, 11:47 PM
  5. Almost finished project
    By TsN|Croc in forum Show off your project
    Last Post: 07-24-2003, 01:33 PM
