Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 48
Thread: The StationRocket WRX is done.
  1. #11
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    Quote Originally Posted by ppgt94
    That looks really good. Someone asked a few weeks ago about how a slot-load slimline DVD drive works in that totally vertical position. So...How's it work? Is it the panasonic?
    yep it's the Panasonic. I haven't had any trouble with it in the verticle position though i don't use it that much. It is a bit louder than i'd expect.
  2. #12
    Sep 2003
    Rochester, NY
    Quote Originally Posted by C4M
    Oooh!
    Do you have pics of your dash installation before putting the bezel back on? I'd be interested in what you had to do to the Xenarc. I've just ordered one for my MY03 WRX.
    Can you show some pix of your sub installation? I have a wagon as well.
    Where did you mount the PC and amps?
    C!
    i took the Xenarc out of it's housing and made some spacers to tilt one of the boards out of the way so it would fit in the WRX dash hole. I then made a bracket that held the LCD and boards and bolted onto the mounts for the OEM radio
  3. #13
    FLAC alti's Avatar
    NY
    slimdrive
    Did you get the ide / usb adapter for the DVD ?
    If it is usb is USB 2 and how are the speeds?
    The install looks great, good job, nice car!!!!
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #14
    Sep 2003
    Rochester, NY
    Quote Originally Posted by alti
    nope i just ran an ide cable from the pc under the drivers seat over to the center console
  5. #15
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    very very nice, I love WRX installs, I cant wait to get one. Great job!
    肚子笑痛了
    S60 Install
  6. #16
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    sweet arse ride man! Well equiped, and Very clean install. Only thing I would do is tuck the wires coming from under the seat, under the carpet. Love the sub enclosure design! I love the WRX. Nice car!
    Status: [|||||||||-] 90% finished
    My 2000 Chevy Monte Carlo SS Install
  7. #17
    Variable Bitrate fly_dutchie's Avatar
    Feb 2004
    Amsterdam
    Great install StationRocket!
    Does the Xenarc fit the standard subaru bezel? Did you glue anything to the bezel or is the whole Xenarc held by the stock double din bracket?
    Michael
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
  8. #18
    Sep 2003
    Rochester, NY
    Quote Originally Posted by snmnetwork
    thought about going under the carpet there but it would have been a lot of work and would make it more of a pain to take it out if i wanted to do some work on the bench. when the seat is in it's normal position it's all out of site anyway.
  9. #19
    Sep 2003
    Rochester, NY
    Quote Originally Posted by fly_dutchie
    Michael
    unfortunatly not only does a xenarc not fit in the standard bezel it woun't fit in the hole behind the bezel in the dash.
    To solve this i had to open up the xenarc and ditch it's factory housing. Inside the factory housing there is a touchpanel, the lcd panel, and two circuit boards. you can find pictures of one disassembled here http://www.talix.com In order to make the whole assmebly shorter (so it will fit in the dash) I tilted the circuit board that has the control buttons back. To hold the board in it's new tilted position and to hold the whole assemble together now that the origional housing is gone I made some parts out of plastic on a milling machine. I'm sorry i failed to take picutres when it was all apart. The part is a rectangle with little wings on the outside to hit the stock radio mounting points. There is a rectangular hole cut in the part so you can see the lcd. There is a recess cut around the hole so the touchpanel and lcd will sit in the recess on a ledge and then be held in by a couple of tabs screwed on in the back. By making those tabs much bigger than they needed to be and sloping thier back side i made a place to mount teh circuit board that needed to be tilted.
    Also i trimmed a little plastic out of the hole in the dash behind the bezel above where the radio origionally sat.
    Sorry for the lack of pics and the clear as mud explination.
  10. #20
    Feb 2004
    Amsterdam
    Quote Originally Posted by StationRocket
    Thanks anyway, your explanation is quiet clear.
    Just another Q: with 'stock radio mounting points' You mean those ON the double din radio bracket or the mounting points who HOLD the double din radio bracket. In other words, did you ditch the bracket?
    Now you can't reach the buttons anymore?
    Thanks, Michael
  1. 2004 Subaru Wrx
    By Zip in forum Show off your project
    Last Post: 12-01-2005, 02:32 AM
  2. Why Impreza WRX?
    By cproaudio in forum Off Topic
    Last Post: 09-29-2005, 03:48 PM
  3. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 10:01 AM
  4. Replies: 15
    Last Post: 03-03-2004, 12:53 PM
  5. V6 holden VS. WRX, suck it SEXREX
    By SOBIL in forum General MP3Car Discussion
    Last Post: 01-17-2004, 06:18 PM
