Page 9 of 10 FirstFirst 12345678910 LastLast
Results 81 to 90 of 95
Thread: Australian Ford XR6Turbo car pc
  1. #81
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    *blink*
    cheers for that!
    Ford XR6T blueprint 4.0 L twin cam turbo.
    Xenarc 7" touchscreen M10000 Audigy 2 NX
    ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
    Griffin Powermate Panasonic DVD-CDW
    Pioneer 5x7 Four way, 2x12 pioneer subz
    600watt 6chan USA audio AMP
  2. #82
    Newbie xcntrk75's Avatar
    Jan 2005
    MD
    Very nice ride and sweet setup too...
    Hey what kind of USB extension cable setup is that plugged directly off the mobo?
  3. #83
    Nov 2001
    brisbane
    USB extention cable
    Its the one that comes with the motherboard, modified a bit. I attached it to the plastic box/unit i made for it and then ran cables to the front plate I made for the dashboard, and used another one (from another computer) there.
  4. #84
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by parawolf
    The inline 6 cylinder falcon is made in Geelong, Victoria. All casting, development and design is done locally. It's a cast iron block for rigidity and durability
    a mates Xr6t had a crack in the block after 1 month. ford had to change the engine.. and on the new engine the cam, cpu and head all had to be changed. 13,000 it cost ford under warrenty
    are few people are having trubles with the heads on the turbos'
  5. #85
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by djmickyg
    Good to see that ford quality is experienced around the world
  6. #86
    Feb 2004
    Quote Originally Posted by 0l33l
    i dont think they could get worse/uglyer than the AU we had here, so thats positive
  7. #87
    Nov 2001
    brisbane
    well this thread has almost died, but I might add something. Ive had to totally take out the car pc and stereo, to get Ford to repair the shocky in the boot under warranty, and while it was all out, I made up new neater cables, replaced all the caps on the MB and freshen up some settings on XP. I also changed and simplified the power wiring, now I can use Hybernate, and it works flawlessly
  8. #88
    Nov 2001
    brisbane
    and now im adding a IR port to try connecting to my mobile phone, and dialing into a ISP to get internet on the road, for stormchasing!
    anyone in Australia on here that can tell me how good or successfull that will be?
  9. #89
    Newbie jaytyn's Avatar
    Oct 2005
    Melbourne Australia
    hey I love your install!!! I am about to attempt to install a carpc into my BA falcon next week...!! You have given me some great ideas as where to mount the LCD!
    How did you mount the LCD there? Did you remove the ICC and screw a bracket to the side of it ?
    Nov 2001
    brisbane
    I made my own aluminium bracket (turned up a sorta knob thing, tig welded a 8mm bolt and washer to get the mount angle just right, non adjustable) bolt screwed into the turned up knob, which is screwed to the 3 x 3 inch aluminium plate, double sided taped to the dash. Surprising how well its stayed there! run the wires down beside the steering column to the pc mounted under the dash, on the drivers side. Its done in a way that will leave no visible signs on the dash if its removed.
  1. A Bodgy Car PC.
    By Bodgy in forum Show off your project
    Last Post: 02-05-2007, 10:58 PM
  2. complete car pc + misc items
    By bluemagic in forum Classified Archive
    Last Post: 09-11-2004, 11:46 AM
  3. Replies: 0
    Last Post: 09-08-2004, 02:42 PM
  4. PC car questions... please help.
    By euclide in forum Car Audio
    Last Post: 05-25-2004, 04:51 AM
  5. About power Supply to PC in car
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 10:39 AM
