Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 69
Thread: My Viahicle install
  1. #31
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    Quote Originally Posted by hd54321
    That is SICK! I love it! Not sure what your rubber piece is made of, but I would look into a rubber grommet and put some grease around the inside dges so the camera moves around easier.
    -HD
    Thanks,
    well the thing is. Is that the rubber piece is not really that hard of rubber, but formed so that it can not be pulled to far in any direction. Know what i mean(hard to explain)...
    I went to Homedepot today and looked up and down every isle. I couldnt find anything that would work. Even looken for some rubber grommets and anything else made out of rubber.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
  2. #32
    Dec 2003
    not sure yet.
    Quote Originally Posted by Grimey
    Dude that's sick! What about like the material they use on lawn chairs? Or some type of strong cloth that will give but keep moisture out. That way it would definitely be flexable. That's such an awesome idea though, mad props.
    thats a good idea. I do have some spear blown air bags here i got from the junk yard (buckers charged me 1.99each for them) i might try that.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
  3. #33
    Variable Bitrate Grimey's Avatar
    Feb 2005
    Moody, ME
    What about the material they use on shifter boots? You could buy one of those cut it down to size and use that.
    Dak TruckPuter:
    Mac: - Researching and Awaiting Funds
    Changed to planning for a Mac Mini Trukputer...w3rd.
  4. #34
    Dec 2003
    not sure yet.
    Wow another great idea. Let me go measure the hole on the body of my truck. Im wondering if it would be able to be cut down so small and fit.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
  5. #35
    Dec 2003
    not sure yet.
    Ok the hole on the body is about 1 5/8" the size of the camera is about 1".
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
  6. #36
    Feb 2005
    Moody, ME
    That's about the size of the opening on a shifter boot isn't it? I would assume you could go to a place like PepBoys or AutoZone or something and pick up one for cheap (measure the hole first) and it should be able to wide enough to cover the larger hole. I don't have a manual so I can't check my friends at home do though. I can't imagine the rod for the shifter is much larger then an inch, it's probably smaller then you can just cut it open a little more to fit it better.
    Dak TruckPuter:
  7. #37
    Dec 2003
    not sure yet.
    right but ya see i only have also another inch in height. Im hope it wont go lager than
    1 5/8" from one 1" in a distance of 1". know what i mean. Ill go today and check. Its a great idea. Thanks.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
  8. #38
    Feb 2005
    Moody, ME
    I think you mean smaller. You'd rather have it start at the 1" opening, go down and get larger then the 1 5/8" hole so you can cut it. Keep in mind you are going to want some slack in the boot, you don't want it to go straight down and attach otherwise it won't rotate. Some slack will let it give to all the sides. Good luck with that, post with how it works.
    Dak TruckPuter:
  9. #39
    Dec 2003
    not sure yet.
    k im going to the junk yard now. ill be back in a little bit.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
  10. #40
    Dec 2003
    not sure yet.
    Ok i got this from the junk yard . Took me forever to find it and froze by butt off. Ya would think a junk yard would have more standard cars. There were like 1 for every 10 automatics. Geesh!
    Now i just have to figure out, what I can use to glue/stick this piece of rubber to my body. Hot glue didnt work but worked well for mock-up. Any suggestions...
    Super glue?
    Thanks Grimey
    Edit: ima stick the part, from my thumb back, on the inside of the truck. So where my thumb is, is where ima glue it.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  4. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
