Getting the work area ready (kitchen table, I don't have a garage)
The bottom of the case HAD to go, that much I knew from Rando. Poor Lilli (I'm using a Dremel for EVERYTHING)
Make some measurements to cut the top of the case for the clips.
Top of the Lilli chopped up.
Like a glove (this is a view from the back)
View from the front
Had to take it fully apart cause I had to trim the bottom of the back also
Here's the work area again, note the plexi with protective blue covering. The mobo is sitting on top of the top plexi piece. Note the ski goggles in the front of the pic.... always wear eye protection.![]()
LinkBack URL
About LinkBacks
) Mobo on top, you can kinda see the HD on the bottom shelf, the Opus is under the mobo.
