99 Acura TL carputer project pics podrias mandarme los planos para contruir uno igual gracias
ffidalgo@cantv.net
Printable View
ffidalgo@cantv.net
I think the peep hole for the PC is great! A really nice install there!
Can you show me how you run the power cable for the amps?
Wow, old thread :P
Can't really show you how they are run, the power is a 4 gauge line drilled through the firewall on the driver's side, to the driver's footwell, under the door sil, to the rear, where it enters the trunk via the ski passthrough. Pretty simple for the most part. From there a distribution block connects the various components to power.
:confused::confused:Do you have a video card on the pc that has composite video out?
Yeah, that was the only way to make the system work with the Kenwood unit.
This install was done before the Xenarc single-din screens were available. If I had an opportunity to redo this install, it would include that screen, as it's easier to use and a higher quality picture than the screen of the KVT-910. Finding room for two screens would be the hard part.
