Page 11 of 58 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 577
Thread: alpine, mcintosh & chopped up liquid cooled dell++
  1. #101
    Oct 2004
    NY
    and backlit....... this is not the finished shot, this is with only 20 luxeon 1's & a heavy diffuser..... when I get the 12 more in there I will need less diffusion, she'll be alot brighter......
  2. #102
    Oct 2004
    NY
    soon I will have this installed..... then the plumbing begins.... I already have the pump.... still sourcing the radiator...... will be some sort of oil or tranny cooler mounted in the grille.......
  3. #103
    May 2005
    Mpls, MN
    are you sure you arent god? btw, how do you control the heating/ air conditioning?
  4. #104
    Oct 2004
    NY
    still working on heating/air cond..... when the system is in I'm going to attempt to control it from the pc.... but I need redundant control incase of pc PMS
    not god btw
  5. #105
    May 2005
    Mpls, MN
    Quote Originally Posted by turbocad6
    not god btw
    lol, your probably gunna need heat for the NY winter, arent you?
  6. #106
    Oct 2004
    NY
    they work fine now, it's just that the factory control is pretty large & not techie looking at all, I'd rather do away with them.......
  7. #107
    May 2005
    Mpls, MN
    ahhh, okay.
  8. #108
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    Just curious, how many SqFt of sound deading material did you use?
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
  9. #109
    Oct 2004
    NY
    not to sure...over $1,000 worth.....
  10. #110
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Okay noob question. I could search and find the answer but where would the fun be. Is there a great improvment when using backlight? Does the normal light from an lcd not output enough light? I know sunlight is a B***H on screens. I have a 15 inch lcd that I was toying with putting into my truck but its hard enough to even see the screen on my current 6 inch LCD screen, during the day.
    What i guess im saying is do i need to spend days milling out heat sinks for high power leds to iluminate my 15 inch lcd screen which will overwhelm my already compact dash? Thanks in advance
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  1. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  2. Buying new monitor for home computer.
    By ppgt94 in forum Off Topic
    Last Post: 08-26-2005, 08:42 PM
  3. Why not use a 1U rackmount server as carputer?
    By index in forum General Hardware Discussion
    Last Post: 08-26-2005, 05:52 AM
  4. Replies: 1
    Last Post: 08-21-2005, 12:16 PM
