Page 4 of 58 FirstFirst 123456789101112131454 ... LastLast
Results 31 to 40 of 577
Thread: alpine, mcintosh & chopped up liquid cooled dell++
  1. #31
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    A man that knows a trully good series when he sees one! Futurama Rocks! I must have seen every episode from the first 4 years 100 times each.
    Your install looks fantastic also!
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
  2. #32
    Oct 2004
    NY
    found more pics, this is what it takes to put a 10" woofer in the door & this shot is before the final dynamat & then a foam filler layer between this & the door panel, not to mention the work to the door panel to kill resonations......there's nothing like having a woofer in your front door
  3. #33
    Oct 2004
    NY
    this is the panel.....pretty much flush mount on these 10"s, the whole inside of the door has a lot of dampening too, up to 7-8 layers in a few strategic spots..., I don't have a picture of the actual woofer, next time it's open I'll get some.....the 10" sub has a front mount neodymium magnet design with cast aluminum frame & carbon fibre cone...... these woofers are awsome & without them this install wouldn't have been possible....they are pretty shallow but hit hard...my doors play down to 12 htz belive it or not, verified on my rta....
  4. #34
    Oct 2004
    NY
    this is a picture of the amp rack while under construction for the mcintosh 4000m, this amp is big & impressive, not to mention pretty awsome as far as sound quality.....
  5. #35
    Oct 2004
    NY
    this is a shot of the alpine d300 touchscreen chopped & built togeather with the alpine h700 processor display, this was originally a retractable display...... not any more.....
  6. #36
    Oct 2004
    NY
    ....a few more shots of the alpine mods under construction....
  7. #37
    Oct 2004
    NY
    ....& a few more, there have been a lot of requests for info on this mod.....
  8. #38
    Oct 2004
    NY
    ...A few pics of the chopped up shuttle.......mute point now as this is going to be ripped out to replace with a pentium m centrino laptop board....the p4 sucks in a car.......
  9. #39
    Oct 2004
    NY
    a decent shot of the custom 2 tone leather with embroidery & perferated inserts......
  10. #40
    _
    Mar 2004
    Little Elm, Texas
    Looks good so far! Would love to see some more pics of the amp rack/stereo install!
    I do like how you have integrated the alpine units into your car, very clean!
    Jan Bennett
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. Buying new monitor for home computer.
    By ppgt94 in forum Off Topic
    Last Post: 08-26-2005, 09:42 PM
  3. Why not use a 1U rackmount server as carputer?
    By index in forum General Hardware Discussion
    Last Post: 08-26-2005, 06:52 AM
  4. Replies: 1
    Last Post: 08-21-2005, 01:16 PM
