hey, thanks guys... good to know that I can inspire some to go beyond what they would normally consider doing, just by seeing it done by someone else.
Im limited in what I can do to the truck while waiting for the electronics to be finished, but I do have to make an overlay for the instrament panel with the new 6.3... I can't really finish that cause I still haven't even been able to get that screen to fire up yet, but still working on that....
I have decided that I will do the overlay for this cluster myself... I considered having a company do it for me, but I think I can do a good job myself really, & once I get all the materials to do it, I can then do many other things with it, & I can try several designs, rather than paying a few hundred for just one piece....
I start by scanning the original faceplate into photoshop, then stitching the 2 halfs togeather to have one faceplate at the right scale, then I can alter & build the layers I need... the faceplate will consist of several transparency sheets stacked to form the faceplate, & then the whole thing laminated or bonded to a thin sheet of lexan...
the good thing of doing it myself is I can play with a few different designs & build them, & then check the results when backlit... heres a sample of one of the files I'm working on, should be as easy as printing this on my printer with full sheet transparency lables, then sticking them stacked to get the end result... I'll see how that works out, & how many layers it takes to get what effect... size wise is fine, as I don't have to do this in one piece, there will be a left & right side, with the whole center being the screen, but all photoshop work is done as one piece
my guess is that this will look best if the final clear sheet is slightly opaque & flat finish, rather than glossy, but I can try both & see.. those 2 red labels aren't finalized at all & will be a bit smaller... & I want to play a bit with 3d effects... I like a 3d looking gauge cluster... I can also play around with lighting.... will this friggin ever end???? someday![]()
LinkBack URL
About LinkBacks
