@grayscale
the keyboard is from keysonic --> http://www.keysonic.de --> produkte.
the motorized mechanism is original from the jvc (from the electronic flip/down front), easy modified for the jetta center console.
Also, what keybaord is that? it's brushed aluminum!
CarPC install is starting to come along again...
@grayscale
Athlon XP3000+, Geforce FX, Audigy2, 1Gb Ram, 250Gb Hdd 3,5", Xenarc 700tsv, CES V3.2, NMC
www.cpcd.de - the german carpc community my project
mech2
Wow, great install.
I hope my project end ups half as good as yours !!
Where did you bought the aluminium trim, just for the upper ac holes in the dash.
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
Very impressive. Dash is awsome.
Must not get very hot where you live though. I think the XP-3000 puts off almost 70 watts of heat and the 5950 puts out 70-80ish watts. You might want to up the heatsink size on both. By the way, I think most (if not all) of the 5900 series graphics cards have thermal diodes built in so you can monitor it's temperature. It's good upto 140°C but I don't think I'd want to run it above 90°C.
Also did you upgrade your alternator or add a battery for the setup? Do your head lights dim if you have both it and your heater on while the car is idling?
Not degrading your system by any means, I'd love to have that setup my self, just giving some heads up, and curious about a couple things.
glow, thx for the dimentions
another quick question, a was goint ot mount the lcd same style in my VW golf IV, but is the screen to hard to read when its up straight ? (not tilted) ?
time for the sig:
'00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
very clean install
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
i've seen his install in real its realy awasome and you would know the hardware is justyfied if you played nfsu in the car once
for Glow i am The-X @ www.car-pc.info
Golf 3 CarPc Status
///////////////50%--------------/
PSU:Inverter
GPS:BT GPS
PC: Slim notebook with 10.4"touch, external DVD.
Dock for car is in production.
Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
@Portugal
very cool sig :-)
the aluminium is original vw, from the golfr32 interieur (bought on ebay)
@YouEatLard
There are no problems with the heat in the housing, I has two 12cm exhausts installed
The system takes up to operated 150 Watts, also nothing colludes itself in the no-load operation of the engine. :-)
With the original Volkswagen battery (70ah)
runs everything (sound with normal volume, without the engine runs) approx.. 4 hours.
then the battery is empty... ;-)
I inserted nevertheless a second battery(60ah) and a larger generator(from the passat w8),
in order to have and bridge the voltage drop with the engine start a longer actual working time
@gerard
I say times in such a way... one can with live, its ok.
I also a half year in such a way around drove.
The touchscreen reflects strongly in this position and you must the contrast more highly place.
If the display drove out diagonally, it is substantially better.
is there any way you could make another aluminum trim piece for that type of screen?
