Page 8 of 8 FirstFirst 12345678
Results 71 to 73 of 73
Thread: 2001 VW Jetta CarPc Install
  1. #71
    Feb 2008
    @ Fluxy - There is usually a bezel that surrounds the area around the faceplate (fills in gaps around the 'plate when it is connected) that you may be able to customize as a "housing" for the faceplate (This might be good if you do not have plans to keep the faceplate removeable)...Also, you may be able to remove the actual pieces the faceplate connects to and mold them into that bezel..Then you would have a relocated, removeable faceplate..
    ...Hope this helps!
  2. #72
    Newbie semaj4712's Avatar
    Mar 2008
    Milwaukee
    how did you wire the deck above the rear mirror?
    2000 Volkswagen Jetta
    -Kenwood DDX512 DVD Touchscreen
    -4 Kenwood 3 way speakers 50W
    -2 Kenwood Twister Subs 1200W
    -Kenwood 2500W Class D Mono Amp
    -Akita 18" Black Racing Rims
    -20" x 7.5" Kumho Racing Tires
  3. #73
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by semaj4712 View Post
    See post #9 of the thread:
    Quote Originally Posted by *Glow* View Post
    @kickercivic1
    the jvc self is in the glove box, its only the actuator on the headliner. the actuator is associated with the jvc on two cat5 wires. there was no other place for the actuator ;-)
    the jvc mechnic
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  1. MKIV VW Jetta Install v2.0
    By ppgt94 in forum Show off your project
    Last Post: 04-28-2007, 04:40 PM
  2. 1997 VW Jetta GLS Install
    By SiGmA_X in forum Show off your project
    Last Post: 08-22-2005, 04:36 AM
  3. VW install help needed
    By migrane in forum General MP3Car Discussion
    Last Post: 09-03-2004, 12:07 AM
  4. Need help for a carpc in 2000 jetta
    By Xc0m in forum Newbie
    Last Post: 07-05-2004, 01:22 PM
  5. EPIA 800 in a VW Jetta 1.8 TURBO
    By samc in forum Show off your project
    Last Post: 10-27-2003, 06:18 AM
