The final location of the amp rack....like how we tried to protect the rest of the car? lol gotta work with what you have!
http://members.cox.net/redgtivr6/IMG...0-%20small.jpg
To mount the amps to the rack we decided to use some t-nuts that we flattened out and then curved to match the curve of the pipe....we then used Super Glues Metal Epoxy....it's sitting up right now...
And another pic of one of my first welds....lol - still need a lot of practice, but this stuff won't be load bearing, nor will you be able to see the welds once we fill it all in and have it painted.
That's it for now!
heh - the welding thing takes some time to get down ;)
yeah it does....only ran 3 beads on a seperate sheet of steel then went to work on the bars.....could look a lot better, but it doesn't need to really....heh
It's been a while... so what's up???? :cool:
yeah - sorry....work has been crazy and the paint on the dash is taking a LOT longer than expected...the weather hasn't been cooperating so it's having problems curing right, this weekend it's no holds bard though on the rest of the stuff we can work on.....so I will be posting pics for sure!
Ok - so here's what little we got done this weekend....metal work takes a while...lol
The ends of the amp rack were rounded:
The tray for the battery bracket to mount to:
This is the battery bracket I will be using:
http://members.cox.net/redgtivr6/f0_12_s.JPG
Upgrading factory grounding with a 1/0, also upgraded the starter power wire to a 1/0 as well....
Power and ground and speaker distribution:
This is all going to be hidden behind the passanger side read pannel. We have removed the speaker grill so that we can easily replace and check the fuses here by just popping out the grill.
The final design for the 'case' if you will, it's not very pretty but it will never be seen, except by those of you here:
Mobo/sound card, haven't tested the sound card yet, will post and let know how it works out:
Hard drive and my crazy mounting method, everything on the board is mounted so that I can easily remove and replace each component without removing the entire board:
The processor brain:
