Page 8 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 71 to 80 of 177
Thread: Redoing the entire install, PC and system!
  1. #71
    _
    Mar 2004
    Little Elm, Texas
    This is a pic of the EMT that we are using for the bars.....we had to sand down the galvanizing finish to prepare the pipes for MIG welding....
    Our new toy: hehehe
    Some of my first welds!
    Jan Bennett
  2. #72
    _
    Mar 2004
    Little Elm, Texas
    The final location of the amp rack....like how we tried to protect the rest of the car? lol gotta work with what you have!
    To mount the amps to the rack we decided to use some t-nuts that we flattened out and then curved to match the curve of the pipe....we then used Super Glues Metal Epoxy....it's sitting up right now...
    And another pic of one of my first welds....lol - still need a lot of practice, but this stuff won't be load bearing, nor will you be able to see the welds once we fill it all in and have it painted.
    That's it for now!
    Jan Bennett
  3. #73
    Newbie Talon's Avatar
    Jun 2004
    Charlotte, NC
    heh - the welding thing takes some time to get down
    www.carolinacarclubs.com
  4. #74
    _
    Mar 2004
    Little Elm, Texas
    yeah it does....only ran 3 beads on a seperate sheet of steel then went to work on the bars.....could look a lot better, but it doesn't need to really....heh
    Jan Bennett
  5. #75
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    looking good
    肚子笑痛了
    S60 Install
  6. #76
    _
    Mar 2004
    Little Elm, Texas
    why thank you!
    Jan Bennett
  7. #77
    Constant Bitrate IonDokk's Avatar
    Michigan
    It's been a while... so what's up????
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
  8. #78
    _
    Mar 2004
    Little Elm, Texas
    yeah - sorry....work has been crazy and the paint on the dash is taking a LOT longer than expected...the weather hasn't been cooperating so it's having problems curing right, this weekend it's no holds bard though on the rest of the stuff we can work on.....so I will be posting pics for sure!
    Jan Bennett
  9. #79
    _
    Mar 2004
    Little Elm, Texas
    Ok - so here's what little we got done this weekend....metal work takes a while...lol
    The ends of the amp rack were rounded:
    The tray for the battery bracket to mount to:
    This is the battery bracket I will be using:
    Upgrading factory grounding with a 1/0, also upgraded the starter power wire to a 1/0 as well....
    Jan Bennett
  10. #80
    _
    Mar 2004
    Little Elm, Texas
    Power and ground and speaker distribution:
    This is all going to be hidden behind the passanger side read pannel. We have removed the speaker grill so that we can easily replace and check the fuses here by just popping out the grill.
    The final design for the 'case' if you will, it's not very pretty but it will never be seen, except by those of you here:
    Mobo/sound card, haven't tested the sound card yet, will post and let know how it works out:
    Hard drive and my crazy mounting method, everything on the board is mounted so that I can easily remove and replace each component without removing the entire board:
    The processor brain:
    Jan Bennett
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. Anyone install PC in Expedition?
    By NorthGaVigor in forum Car Audio
    Last Post: 10-11-2005, 09:48 PM
  3. mini cooling system from notebook, can be used on car PC
    By dragonBTV in forum Power Supplies
    Last Post: 11-12-2004, 01:52 AM
  4. My PC plans - anything wrong with this system?
    By mx270a in forum General Hardware Discussion
    Last Post: 09-02-2003, 07:32 PM
  5. controling ac system with car pc
    By sugarmychurro in forum General Hardware Discussion
    Last Post: 05-21-2003, 02:17 AM
