Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 78
Thread: 1997 BMW M3 in progress.....
  1. #31
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by BoyNextDoor
    well, WE certainly are awaiting those pics... i'm crious how the pc looks in another mans car
    cheers
    Would you be just as curious to see pics of an old girlfriend in another mans bed?
  2. #32
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    So where'd you get the Transformers shift knob emblem? Buy it? Make it?
    I want one! That's my avatar on every board I'm on.
    2005 Subaru Legacy GT
    Status: 40% - starting install
    • AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
    • JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
  3. #33
    Nov 2004
    San Diego & Fort Hood, Texas
    Quote Originally Posted by John M
    Can you transform?
  4. #34
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    I made it.
  5. #35
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    Quote Originally Posted by Enforcer
    I really don't know about that... But a pc is different don;t you think?
  6. #36
    Dec 2004
    Baltimore, Maryland
    I'd venture to say FAR too many people, mostly living in mom's basement, don't see a difference. So sad.
    I swear I'll get pics of this setup up today. It's been a busy weekend.
  7. #37
    Low Bitrate got2liv4him's Avatar
    Oct 2004
    Gonzales, LA
    yokudekima****a!
    (Great work!)
    Kimi ga kawareba, Seikaimo kawaru!
  8. #38
    Dec 2004
    Baltimore, Maryland
    Well I finally got more pics, but now Photobucket's broken. haha...
    Oh well, maybe in an hour or so.
    The best part about the pics I have is that they don't show much. It was s uprisinly simply install and easy to conceal.
    The only thing I'm going to change, besides adding the touchpad device next to the parking brake, is to redo the way I secured the CPU. Right now it's simply velcroed to the rear trunk mat. It's a solid install suprisingly. The thing does NOT move. (Velcro is amazing stuff). But I decided I'd like to add alittle bit of shock absorbtion. So I'm going to fix a 2 inch thick peice of foam rubber to the bottom of the computer and then have the foam rubber velcroed to the trunk mat. That should keep it just as securing in place but give me a little added shock protection. Plus it should compensate for the uneven trunk floor which now requires me to have the system sitting in the middle of the trunk. When I re-do it (we're talking about 10 whole minutes of work to redo this) I'll be able to re-orient the CPU to face the rear seat so in the event I need to access it from in the car I can just fold the seat down and have it there!
    My other modifications that I'm going to do (amazing how your plans seem good on paper but once you impliment them you always realize a slightly better way) ar eto rewire the screen and add a switch to the switched power source (I'm sure that's no confusing...haha)
    I'm going to move the hot wire of the screen from the cig lighter feeds to the switched power line so the screen is only powered when the car is on. I've realized in the few days I've had the computer going that I'm incapable of remembering to turn on the monitor when I get out of the car. Also, I'm going to add a switch to that same power line AFTER the monitor. That way in the event the computer hangs up on startup or anything else goes wrong with the automatic start up controller or Windows freezes or something, I can still cut power to the system manually without having to stop, get out and go to the trunk.
    Those two wiring modifications should take me probably about an hour tops with the dash fabrication. That switch will be easy to put into the dash because the console in front of the screen where the fan and video inputs are have 1 blank opening waiting for me to put a switch in. It's just a matter of cutting a hole in that plastic peice and glusing a switch into it.
    So that's the project status thus far. Hopefully I can get pictures up tonight.
  9. #39
    Aug 2004
    Walden, NY
    if you need space, i have it... i can host the pics for you darn it, just have them up... sendme pm...
    cheers
  10. #40
    Dec 2004
    Baltimore, Maryland
    Allright, Photobucket is back in action...here we go...
    This one is the whole user interface section as seen before.
    The wires from the screen, the usb touchscreen, and the switched power wire all run under the center console and come out to the side of it behind the passenger seat. While it's kinda ugly, you can't see it at all when the seat is back. So the only time you'll see it is when someone's getting in the back seat. once they are in, the wires go back to hidden.
    Those wires run under the floor mat in the back to the corner where the seatbelt it secured to the car. They go up to the crease in the seat from there....it worked out that the monitor cable connector to teh extention cable came to that exact spot and those connectors wedge in behind that metal bar perfectly. No other fasteners needed.
  1. Opinions on the BMW M3
    By Rith in forum Off Topic
    Last Post: 05-05-2008, 11:27 AM
  2. 2003 BMW M3 Custom Dash / Overhead Console
    By gork in forum Show off your project
    Last Post: 01-01-2008, 07:52 PM
  3. E46 BMW guys, any thoughts?
    By GeddyT in forum Newbie
    Last Post: 03-09-2007, 09:08 AM
  4. 2001 BMW E39 - fully integrated Carputer
    By tsingsu in forum Show off your project
    Last Post: 05-03-2006, 04:51 PM
  5. 03 BMW 330i Dinan S3 Project
    By fattytl in forum Show off your project
    Last Post: 09-27-2005, 10:24 PM
