Page 4 of 10 FirstFirst 12345678910 LastLast
Results 31 to 40 of 96
Thread: Stealth OEM install in MR2 Spyder - Magazine coverage!
  1. #31
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    Oh yeah, i left out some background information. When using the vb app that phidgets gives out as demos, the phidgets manager properly detects two unique devices w/ two UIDs, so I'm certain its not a hardware problem.
    Unfortunately, when I run this portion of the script
    PE = luacom.CreateObject ("PHIDGET.PhidgetEncoder")
    PE:Open(0)
    print ("Number of Encoders is ".. PE.IsAttached)
    print ("Serial ".. PE.SerialNumber)
    print ("Version " ,PE.DeviceVersion)
    it only responds w/ 1 encoder and returns the serial number of the newest one. And yeah... the same behavior occurs when I start the system w/ both plugged in. I'm totally baffled
  2. #32
    Constant Bitrate dingofarmer's Avatar
    Oct 2004
    colorado
    Quote Originally Posted by silencery
    yeah, i didn't want to mount it horizontally, but due to space contraints in the case... I had to stick w/ that for now.
    I've got a firewire enclosure on the way, so I'm gonna experiment w/ mounting the main HD or a spare HD vertically in the glove compartment or something. I'm pretty paranoid about head crashes so I'm gonna do something about it soon.
    Originally, as you might be able to tell in the picture of the hard drive, I was messing around with some drive suspension/shock-absorbtion techniques. The transparent string you can kinda see in the image is a semi-elastic silicon material which I think has a lot of potential. Its called Stretch Magic, and its a material used in making craft bracelets. I'll bet someone can make use of it sometime down the line.
    Once again, due to space constraints though, I had to ditch the idea.
    Sorry to hear bout your car by the way. I saw that other post about the hit... thats gotta be painful
    dingofarmer,
    Ooops, I forgot to mention the amp... haha. I've got an amp in the back and the line-out splits into two channels -- one to drive the front components and one to drive the sub. I'm looking into sound card options right now cuz i'm not all that happy w/ turning the gains up so high. I'm skeptical about finding anything though.
    hd54321,
    the nav pod was actually fairly cheap. I bought it new from some guy off the mr2 board for about $45 cuz he didn't wanna use it anymore. Even new, it doesn't go for more than $100; I'm guessing its a lot more simple than the subaru pod.
    BTW, japanparts.com is a good source for OEM japanese parts; i dunno if the WRX pod you mention is a JDM part or not, but maybe it'll help someone.
    Spaghetti,
    Thanks for the kind words I love my car man.... it drives like its on rails... seriously. just got like a billion payments left!
    similar prob myself, I bought a panasonic ac300, slit it all up for me,sub,front l/r, back l/r, Center. I'm back into a HU, so I'm about to sell it. Alpine and pioneer make DSP/surround processors that are similar. might fit in nice with your install, bTW Iwas using the optical out on my sonica soundcard to the unit. I didn't have to boost my gains like when I was running from the card, directly to the amps. Nice setup, I mean really nice.
    John
  3. #33
    Oct 2004
    Los Angeles, CA
    Thumbs up Dude, I can't believe you did this!
    My bro mentioned that you were putting together a carputer the other day when I was talking to him about my ideas for one. I'm glad at least one of my friends is crazy enough to try this. Of course, I should have expected this from the guy who takes the time to separate each strand of his flat IDE cables in order to make them round and improve airflow in his PC. Super clean install. I'll be calling you for advice when I get around to doing my carputer. Certainly a step up from the days when you used your Pocket PC for a video player in your car, eh?
  4. #34
    Constant Bitrate Gibson99's Avatar
    Aug 2004
    Houston, TX, USA
    one thing i never saw mentioned was the fact that this car is a convertible! how does the screen do in the daytime with the top down? still readable? is yours a touch or did you get/make a non-touch lili? i'm about to put a touch lili in my mazda miata (mx5 for those outside the US), and sunlight washing out the screen is my biggest concern. i'm gonna put it back as far in the dash as feasible for shade, but i worry about not being able to see the sides of the screen, or feeling like i'm reaching down into a bucket to click stuff on screen, ya know? not enough room behind my radio to mount my mobo or an optical drive in there... my heater core is directly behind the HU and it's a TIGHT fit.
    you're kinda lucky you had that door thingy on top of the dash as a place to mount it. it's funny... every time i get in a car at work (toyota dealership) i try and figure out where i'd hide a screen in it.
    Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
    Current: CamryAmp 2.0 - 98 Camry CE V6 5spd (still bench-testing)
  5. #35
    Jul 2004
    Los Angeles, CA
    Gibson,
    Yeah, that's a good point. To be honest, I'm not sure how the screen performs w/ the top down since I've still got the hardtop on for the winter (although here in LA its basically summer already). I'll probably store the hardtop again in a few weeks and I'll let you know how it turns out.
    I'm willing to bet though, that there's gonna tons of glare. Right now, the monitor shroud (the door thingy replacement peice) does a pretty good job w/ keeping the glare out, but there are still instances where the sun will strike it at precisely an angle to wash everything out. To be honest though, I drive mostly when the sun is starting to set or has already set. When daylight savings time comes up, I'll have a better idea of how it performs in daylight.
    While mouting the lilli in that position helps visibility, it makes it nearly impossible to use the touch function while driving, at least not safely. I normally have to lean forward by about 6 inches just to reach it. Thats the reason I decided the modify the stock knobs and buttons to act as inputs; this way I don't have to worry about using the touchscreen when its inappropriate.
    The JDM shroud thing is pretty cool, it opens up from the screen to a wider area, so it doesn't feel like you're confined when looking at it or using the touchscreen. I'll take more detailed pix later today to show you what I mean.
    Awesome car BTW, miatas are a ton of fun
  6. #36
    Aug 2004
    Houston, TX, USA
    ok, since you mentioned leaning forward to touch the screen, i guess yours actually is a touch. i only brought that up since the touch panel overlay decreases screen brightness and clarity. mine's one of the "newision" lili's with touch. haven't played with it much, but it's a little brighter than my dell laptop, which i think has like 150 nits brightness (drops lower when on battery)... and with the top down and the sun shining on the laptop screen, you can't hardly read it at all (on battery). i think i'll probably be ok as long as i can make some shade for the lili in the dash. i bet toyota probably uses a 300+nit screen (w/ autodim for night) in their jdm mr-s nav screen so that it's visible w/ the top down. they use a pretty good screen in their other indash apps like the sequoia, avalon, camry, etc, and i have yet to see them wash out in sunlight, but then again all those cars have solid roofs. i like how toyota seems to put actual THOUGHT and long-term testing into their products, unlike some american manufacturers.
    thanks for the props on my car... it's my little street legal go-kart
    before i bought the miata, i looked at getting an mr2 or mr-s as well when i was originally shopping for a 2-seater. i had a big problem with the original mr2 - the dead pedal is too close to the clutch, and i just can't shift fast in there - my foot always catches the edge of the dead pedal and my brain registers the stop so i move my hand to shift but it always grinds since i didn't have the clutch all the way in. then for the mr-s - it just doesn't have enough storage space to be practical as an ONLY car, plus i didn't like the way it handled, and i can't adjust much in the alignment department on the mr-s. the miata has an actual trunk (though admittedly it isn't huge, but it is possible to fit 2 golf bags (with clubs) into the trunk... try that in a '2! granted, i don't golf, but it gives you a good idea of the size. also, the miata has so much adjustment possibility for alignment, i can set it EXACTLY where i want it for my autocrossing. anyway, the insurance cost was the biggest deciding factor for me. insurance on an mr2 turbo is the same as a CORVETTE, and the mr-s was only a couple bucks lower than that... whereas the miata was less than half what a vette costs to insure. funny thing is, the 97 miata is cheaper to insure than my previous car - a 95 v6 camry coupe!
    anyway, please keep me updated on how the screen does once the HT comes off. funny thing, those hardtops... i don't plan on ever getting one - it only gets cold about a month out of the year, and i'd have nowhere to store it for the other 11 months. just not worth the $1000+ and hassle.
  7. #37
    Jul 2004
    Los Angeles, CA
    Yeah, my screen is a TS lilliput.
    haha, yup the storage space is a big issue for most people. I thought it was crazy too until I realized that I'm driving by myself most of the time anyways, so I just use the passenger compartment for most of my storage needs. Some of the more hardcore guys just take out their passenger seats to move stuff around.
    If I ever need space, I just borrow a friend's or my gf's car.
    I actually love the way the mr-s handles, but the miata is an excellent handling car in its own right as well; the weight balance is quite good. Add that to the fantastic aftermarket support, and you have an exceptional roadster My friend just bought a used turbo kit for $500 off some guy a while back for his 93 miata!
    Interestingly, mr-s insurance costs for me are quite low. With the exception of the guys w/ poor driving records and the high school kids, people on the spyder forum report that they generally pay reasonable rates. Here in my area, i get billed about 750 for the year which I understand is pretty reasonable for full coverage+ in Southern California. I think part of the reason is since the HP rating is so low.
    Of course, that doesn't take away any of the fun for me
    The reason I actually bought the hardtop was cuz someone slashed the softtop to try and break in a while back. The lame thing was all they stole was my change @@!)!@(!)!)!) Ugh. The benefits of it on an mr-s are pretty apparent once you have it on though. I dunno if its the same for miatas, but the chassis stiffens up quite a bit and the rear visibility is MUCH better (the poor excuse of a window in the back doesn't do much for visibility). I don't have chassis braces yet so when it comes time to take off the hardtop, I'm always a bit hesitant.
    Once daylight saving time hits here in so cal, I'm sure visibility on my lilli is gonna go to **** Like I said before, the shroud helps, but direct sunlight is still a killer. I'll be sure to keep ya posted.
  8. #38
    Jul 2004
    Los Angeles, CA
    edited with updates...
  9. #39
    FLAC ppgt94's Avatar
    May 2001
    USA
    silencery that looks so good. Great monitor positioning. I also really love you stealth install. Now interfacing the buttons and knob! Very nice work. Do you have any pics of how you rigged the knobs? I'm having trouble visualizing the mouse wheel and rotary parts behind the knob.
  10. #40
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by ppgt94
    They aren't mouse knobs. They are knobs from phidgets.
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 11:21 AM
  2. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 06:24 PM
  3. Beginning of the install pics
    By ddt in forum General MP3Car Discussion
    Last Post: 10-22-2002, 01:34 AM
