Results 1 to 8 of 8
Thread: Rebuilt my Carputer with 2 PSUs.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    No Bose hating please - I used to install commercial Bose systems, and my car has Bose factory audio with an extra 12" so I'm partial to Bose.
    Anyway, the CDRW is for sharing data at meets. The black panel under the Bose emblem covers the floppy cage which now houses the Carnetix 1260.
    Here you can see the layout. The Opus 150 powers the MB, HDD, PCI, Video and the Carnetix 1260/PW-70A powers the screen, USB hub, case fans, and USB DVD drive.
    Video is a Ti4600, PCI holds Audigy, PCMCIA adapter with 200mW 802.11b, and a USB 2.0 dedicated to the dash USB DVD. All other USB devices are on the on-board controller and the D-Link hub.
    Rear view shows the Opus and Carnetix inputs. The Opus startup/shutdown controller is used and the Carnetix is just a slave.
    The red and yellow pairs are +12 and +5 outputs from the PW-70A to the external devices.
    Fabricator
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    Very nice Mike if i only had the skills and money lol
    Jan 2003
    Ruston, LA
    That's exactly what I'm going to do.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Constant Bitrate Rith's Avatar
    May 2004
    P'cola, FLA
    Looks pretty bad ***. Bose sucks thought. J/K, I love bose.
    Your car pc > my best desktop
    CarPC Status:
    [||..........] 12%: Planning
    Have:
    • IRman • PS2 Remote • USB 2.0 Powered Hub • Backup HD
    Coming Soon:
    • Aopen Pandora • Celeron M 1.4 CPU • 256/512 DDR2 So-DIMM RAM • Lilliput 7" Touchscreen VGA • Car Power Supply (M/Opus)
    Low Bitrate BrUTaL's Avatar
    Dec 2003
    Guayaquil - Ecuador
    That case looks pretty similiar to mine, where are you your carputer? Do you have more pics on your install?
    Progress = 50%
    CarPC: INTEL Desktop Board D201GLY | 20GB 2.5" HD | 1GB DDR PC5300 | Lilliput 7" VGA TS | OPUS Solution 150W DC-DC ATX | Stowaway Universal Bluetooth Keyboard | Reverse Camera | Windows XP SP2
    Oct 2003
    WI
    Quote Originally Posted by BrUTaL
    Its been done twice now. This is v3 new for 2005. I had the PW-70a integrated with a relay last year, but didn't realize that the 12V was unregulated back then. The Lilli, dash DVD, and hub seems to have survived the 14V luckily. The learning experience never ends. I think my carputer assembly/install labor vs. carputer usage time ratio is about 10:1 lol. If I ever paint and install all my parts I'll post new pics.
    Fabricator
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    I'm thinking about doing something very similar to this as well. Though instead of the carnetix, i'll be using the ITPS, and I will be installing the PW-70A and the ITPS in my dash, while my mobo/hard drive will be powered by another PSU in the trunk.
    I'm just not so sure how to go about the whole deal. Will the PW-70A power on without a connection to the motherboard? I've never powered on an ATX PSU without a motherboard.
    Also, couldnt I just use the ITPS to power the LCD, optical drive, and usb hub?
    PC Components:
    My work log
    Oct 2003
    WI
    The ITPS will work as a voltage regulator, but it won't maintain 12V through a crank because of the dropout voltage so you'll lose power to those accessories while cranking. You can power it on with an ignition input same as the Opus or Carnetix though.
    The optical drive requires 5V also and the ITPS alone only provides 12V with a minimum 13.5V input.
    The ATX PSUs can be turned on by just shorting two terminals on the connector.
    I haven't tested my new setup yet, but I'm confident I have it done right this time.
    Fabricator
  1. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  2. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  3. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  4. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  5. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
