Page 8 of 8 FirstFirst 12345678
Results 71 to 79 of 79
Thread: StevieG's Ford Focus Car PC
  1. #71
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by Cris
    Hey Stevie, considering you've mounted everything really stealth, do you experience any heat problems? I mean with the amp and pc. I wanted to mounted in a similar way, but I was afraid of something going wrong...You're brave man!
    I thought I might do but no problems!
    Last week I even braved it further by putting the top of the morex case on, as a new addition of a Nokia PCMCIA GPRS card caused some buzbuzzbuzz mobile problems until the MB was sheilded and expected to have a problem or two, but a 6 hour drive didn't cause a single problem.
    There is a little secret however, there is ventilation either side of the boot in the focus, which was hidden away by the carpet but now right by the Car PC itself, which is why I didn't need to cut the vents I had thought I'd need!
    Steve
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  2. #72
    Maximum Bitrate Davefocus's Avatar
    Mar 2005
    Norfolk UK
    Stevie,
    Does the Opus PSU have a pulse start feature (I'm using a Carnetix P1280) and are you using it?
    If so, where have you taken the pulse from on the focus to activate this function? Do you know whether the ford alarm could supply a pulse?
    Dave
    Vauxhall Astra SXi Car PC installed.
  3. #73
    Mar 2005
    Norfolk UK
    Quote Originally Posted by Davefocus
    Stevie,
    Dave
    I have found an earlier reference you made to http://www.digital-car.co.uk/forum/viewtopic.php?t=674.
    Sorry, I will research more thoroughly next time.
  4. #74
    Ireland
    Stevie,
    Dave
    i'd be interested in knowing this too. I'm assuming you're interested in starting the computer remotely?
  5. #75
    Ireland
    how did i miss that post?
  6. #76
    Jun 2005
    NJ
    Nice install. Seems most put the computer in the trunck. What do you do about access during a ride?
  7. #77
    Mar 2005
    Norfolk UK
    Quarryman,
    Decided against remote pulse start as the CarNetix P1280 provides adequate ignition control, resulting in a simplier system for me.
    Dave
  8. #78
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by dapure
    I use an LCD monitor with touchscreen plus steering wheel stalks. I've never had to access the physical hardware on a journey.
  9. #79
    Oct 2004
    NY
    just thought I'd chime in.. awsome looking install.... that dash really looks pro! a square into a rounded panel isn't so easy to pull off, but yours looks perfect with the rounded recesses on the sides.....keep up the good work.....
  1. A Bodgy Car PC.
    By Bodgy in forum Show off your project
    Last Post: 02-05-2007, 10:58 PM
  2. Replies: 15
    Last Post: 02-14-2006, 11:50 PM
  3. Car PC and LCD searching
    By ascarytiger in forum LCD/Display
    Last Post: 12-01-2004, 06:12 PM
  4. Replies: 1
    Last Post: 11-27-2004, 05:16 PM
  5. Replies: 0
    Last Post: 09-08-2004, 02:42 PM
