Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: 2 LCDs 2 touchscreens sport trac, check it out
  1. #11
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Damn. That's sick. Now I'm thinking of relocating my head unit...hmm..
  2. #12
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Great install!! And, the Bloodhound Gang rule!!
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
  3. #13
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by dodgetimes2
    You don't have to defend Hot Glue so much, believe it or not I've taken apart many consumer electronics and have found Hot Glue being used quite often (mostly to hold down wires). Sometimes you have to use it, that or Epoxy works great to, but also is much harder to remove if you f@ck it up.
    Werd. Hot glue rocks for keeping wires in place!
  4. #14
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Nice install
    I like the HU in the A pillar, looks smooth...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #15
    Low Bitrate Sporttracguy's Avatar
    Jul 2004
    Puyallup, Washington
    Thanks guys, keep it coming.
    oh, i had a question,, ive been using mediacruiser as my software and im curious if there are better ones outthere? i tried to load frodoplayer but i couldnt get it to work correctly
    Sporttracguy
    Here are some shots of my ride, be sure to scroll all the way down:
    http://www.cardomain.com/memberpage/674459
  6. #16
    Jan 2003
    Ruston, LA
    We all use hotglue !
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #17
    Oct 2004
    NY
    hot glue is great for many things, but don't use it to mount or assemble your dash or anything heavy, unless you want to see what happens in the middle of the summer with the windows rolled shut in the sun, it does soften up pretty easily..........just because a so called pro uses it to mount stuff doesn't mean that's the best way to do it..........nice truck & install, you look like you have a lot of patience & desire, good luck with it........
  8. #18
    Jul 2004
    Thanks for the comments guys,, Im a 21 year old college student. I recieved the truck used with 6k miles on my 18th bday,, ive been working on her steady since then.. my hope is to go into industrial design where i can put my skills to work..i spend alot of time working on the erganomics and asthetics of the install and fabrication to make it look like it belongs
    Thanks again and keep the comments coming
    Sporttracguy
  9. #19
    Maximum Bitrate nFiniteTuning's Avatar
    Albuquerque, New Mexico, United States
    Hot Glue works wonders. I done alot of custom work with LED's....and after I had them wired...I needed somethin good to hold them all down and keep the connections from touching, hot glue did it perfectly!
    -Josh
    1997 Mitsubishi Eclipse GSX
    My URL: https://www.facebook.com/jagray85
    XBOX: DarkerStars
  10. #20
    Oct 2004
    NY
    hot glue is awsome for wiring work, & is awsome for many things, but I have also seen even professionals mis-use it sometimes where it isn't adiquate, & I just wanted to get the point across that there are somew instances that it is not desirable.............
  1. My 2001 Sport Trac Install
    By wkolodny in forum Show off your project
    Last Post: 01-30-2008, 11:18 AM
  2. Replies: 35
    Last Post: 02-04-2005, 02:46 PM
  3. Sport Trac Carputer with factory HU
    By defunctionjs in forum Car Audio
    Last Post: 09-26-2004, 11:59 PM
  4. Slightly confused about LCD's & Touchscreen's
    By -al- in forum LCD/Display
    Last Post: 09-02-2003, 10:39 AM
