Page 13 of 16 FirstFirst ... 345678910111213141516 LastLast
Results 121 to 130 of 151
Thread: 2004 VW R32 Install - NOT DIAL-UP FRIENDLY
  1. #121
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Quote Originally Posted by Man Ace
    How do I connect my soundcard to the monsoon amp input though?
    I haven't forgotten you! I'm debugging a machine with the dreaded blue screen of death (fatal exception error) and working on a wedding in my free time, not to mention that faceplate that seems to be in high demand! I should be able to produce something valuable by the end of the week.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
  2. #122
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    clean.
  3. #123
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    awesome install.. I will soon do the same to my fiance's 337...
    as soon as you have time to finish the faceplates that is....
  4. #124
    Nov 2004
    North Atlanta
    Quote Originally Posted by strohj
    Thanks, man. Will rekindle the fire under the machinist before the end of the week.
  5. #125
    Nov 2004
    North Atlanta
    :d
  6. #126
    Constant Bitrate trance728's Avatar
    Mar 2005
    Huntington Beach, CA
    done, anything for a fellow dubber, and thanx for all the help with my setup too
  7. #127
    Nov 2004
    North Atlanta
    Talking
    Quote Originally Posted by trance728
    Thanks!
    Have your friends vote, too!
  8. #128
    Feb 2005
    Hi Mate,
    Excellent install. Kudos to you.. and Good Luck to you fiance... or it the wife? Anyway, mate, I'm new to all of this and was wondering, you've got yourself a pretty fast processor there and a fair amount of items hooked up to your PC. Is everything powered from the Opus that you have? Do you need to make any modfications or special setup to get enough power?
    I've gone through all sorts of power calculators and could never get the calculated power below 150Watts. Hope to hear from you sson mate..
    BTW, I did vote for your lovely fiance. Hope everything turns out great for her.
    Malaysia
    -Alfa Romeo Giulietta 1982 with 1992 Alfa 75 2.0 Twin Spark Engine-
  9. #129
    Nov 2004
    North Atlanta
    Quote Originally Posted by alfabob
    Hi Mate,
    It's official as of May 15th, she's a wife. And thanks!
    Just about everything IS hooked up to the Opus. If I recall correctly, my wattage calculator readings were at 168 Watts. I read that the calculators were running high, so I rolled the dice and went with the 150 Opus. I did not hook up the neons to the Opus. They are powered from a separate voltage regulator from ACC power. BUT, the monitor, 7-port hub, mobo, DVD-Rom enclosure and all the USB components ARE driven by the Opus. Hope that helps.
    I've gone through all sorts of power calculators and could never get the calculated power below 150Watts. Hope to hear from you soon mate..
    It's been a while, so my memory is fuzzy on the details, but I did MAX amperage draw tests of the components that I was planning to use. I then converted amps into watts and my own personal readings were well within the 150W spec of the Opus. Thanks for the vote! And good luck on your system!!!
  10. #130
    Feb 2005
    Mate,
    Thanks so much for replying so quickly. I'm now pretty sure that my planned system would work, and I'll do the amperage draw test onf the components to make sure it does. And Congratulations on the wife mate. Very happy for ya. You must be feeling on top of the world now... great computer setup installed in the car, and a great Wife installed in the household!
    Malaysia
  1. 2001 VW Jetta CarPc Install
    By *Glow* in forum Show off your project
    Last Post: 03-27-2008, 03:00 PM
  2. need tips for 2004 accord sedan install
    By keghead in forum General MP3Car Discussion
    Last Post: 07-07-2006, 04:48 PM
  3. 2004 Bmw 545 Install
    By turbodman in forum Show off your project
    Last Post: 03-01-2005, 01:52 AM
  4. 2004 VW GTi VR6
    By TurboBmaNN in forum Show off your project
    Last Post: 01-03-2005, 05:07 PM
  5. VW install help needed
    By migrane in forum General MP3Car Discussion
    Last Post: 09-03-2004, 12:07 AM
