Page 14 of 16 FirstFirst ... 45678910111213141516 LastLast
Results 131 to 140 of 151
Thread: 2004 VW R32 Install - NOT DIAL-UP FRIENDLY
  1. #131
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Quote Originally Posted by alfabob
    Mate,
    Thanks so much for replying so quickly. I'm now pretty sure that my planned system would work, and I'll do the amperage draw test onf the components to make sure it does. And Congratulations on the wife mate. Very happy for ya. You must be feeling on top of the world now... great computer setup installed in the car, and a great Wife installed in the household!
    Always happy to help! And thanks for the kind words.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
  2. #132
    Nov 2004
    North Atlanta
    So much for good times... Sony just did something to their servers and Teresa's score has been DECIMATED!!! PLEASE go back and reset your vote to 10. I've checked and the vote I gave her myself was reset to 4. Her score was at 7.05 this morning. But now it's at 4 and with that score she will not even get considered for the competition. Thanks for your support! Here's the link with all the info, again.
    http://www.tnoreen.com
    Please post if the score you placed was also reset to 4 and take a few extra minutes to score all the other gals, please, so that I know they're not disregarding your vote for only voting.
  3. #133
    Nov 2004
    North Atlanta
    Sony fixed the problem - they got hacked!
    Thanks for all the help, everyone!
  4. #134
    Constant Bitrate NeckPayne's Avatar
    Jul 2005
    Detroit, MI
    Glad things worked out with the server....I went through that site and the majority of the contestants were ridiculous (i.e. - no shot in hell).
    Anyway...any chance of you including a wiring diagram on how to get that monsoon amp to turn on when using the carpc instead of the HU? Its the only thing keeping me from buying the components and at this point I'd really like this project to get in the way of life
    Thanks!
  5. #135
    Jul 2005
    Michigan
    Looks nice to me
    Absorb, elaborate, plan, execute.
  6. #136
    Nov 2004
    North Atlanta
    Quote Originally Posted by NeckPayne
    Thanks!
    Sorry to keep you waiting for that wiring diagram. Hope this helps!
    BTW, Teresa is a finalist in the contest. We're in Vegas this weekend!
  7. #137
    Feb 2005
    Atlanta, GA
    It's been a long time. I'm starting to get the carputer bug again. I know I shouldn't with my job still in limbo. Anyways, glad to see you're hitched, fixed the Monsoon issue, and still breathing.
    I just need a little confirmation in what you found out about the amp. In searching the 'tex, most of the articles state that the Monsoon amp isn't truly an amp and the inputs must at be speaker-level and not line-level. The stock HU did most of the amplification and replacing it with an aftermarket HU would require using the builtin amp. I am going to assume that most of these threads were for the Single Din stock HU present in the 1999.5-2001(maybe 2002) Mark IVs.
    From reading what you've done, it looks like you're putting line-level to the monsoon amp. This suggests the Double Din Monsoon setup in 2002(maybe 2002.5)-2005 Mark IVs has a true amp that does all of the amplification and the HU doesn't do any amplification.
    Would you concur on this or have I missed something?
  8. #138
    Nov 2004
    North Atlanta
    Quote Originally Posted by Fuzzball
    I concur 100%!
    I measured the A/C output of the speakers before the Monsoon Amp - after the radio, in other words. And since it's a rapidly varying signal and it is dependent on whatever music is being played, it is not an exact science! But my readings were roughly 200 mV - roughly the same voltage you will measure directly out of your carputer. The graduated volume level display on the VW HU and the computer's volume can be set to identical levels (graphically). From there, it's easy to verify that the line-level voltages are very close to the same.
    I conducted some trial and error testing using the misinformation on the boards (here and 'tex) about "amped" inputs and the results were horrific - lots of speaker popping and screaming going on!
    We missed you at the R32 GTG, by the way! http://forums.vwvortex.com/zerothrea...15933#22315933
  9. #139
    Jul 2005
    Detroit, MI
    I thought previously you had said to put the 5v signal through the common or (-) line?? Guess I totally misunderstood.
    Thanks for posting this!!!
  10. #140
    Nov 2004
    North Atlanta
    The diagram is corrected to show connection to the common line. I verified that our R is wired according to the corrected schematic. Thank you for correcting my mistake - I was running off memory - foggy memory, at that!
  1. 2001 VW Jetta CarPc Install
    By *Glow* in forum Show off your project
    Last Post: 03-27-2008, 03:00 PM
  2. need tips for 2004 accord sedan install
    By keghead in forum General MP3Car Discussion
    Last Post: 07-07-2006, 04:48 PM
  3. 2004 Bmw 545 Install
    By turbodman in forum Show off your project
    Last Post: 03-01-2005, 01:52 AM
  4. 2004 VW GTi VR6
    By TurboBmaNN in forum Show off your project
    Last Post: 01-03-2005, 05:07 PM
  5. VW install help needed
    By migrane in forum General MP3Car Discussion
    Last Post: 09-03-2004, 12:07 AM
