That depends on a few factors. I'm trying to determine customer demand - as in, what does my customer want? Ideally, I'd like to see the piece done in aluminum. If someone wants it done in plastic, instead, I need to know. Needless to say, there has been a good bit of demand.Originally Posted by jaded_gti
I also need to determine if everyone is going to be using Mapower enclosure. If they are, then it would be exactly like mine and simpler to build. If they aren't... well, then things start getting complicated.
I need dash parts. I want to design this thing so it's perfect OEM grade for everyone. Problem is that I can't have my fiance driving my car while I tear has car down for measurements/engineering. I've hunted all over Atlanta trying to find a used center dash piece to no avail. If someone can get one from a junkyard and get it to me along with the HVAC control panel (manual is cheaper, but Climatronic would work too) then I can move forward much quicker.
I'd be happy to do this and can most likely keep it under $100 per unit, but I gotta tackle those issues first and need help/input doing it. PM me?
LinkBack URL
About LinkBacks
I use it for volume control. Call me old school, but I'm not a big fan of touch-type volume controls. And I admit it is farther from the driving position than I'd like. I simply could not find a better solution. My fiance drives the car, primarily and at 5'5" she has yet to complain about the reach - and she's not one of those gals that sits pressed up against the steering wheel, either! In fact, I've asked her about her opinion of it and she says "It's great".
Next month it should be warmer - just look for Teresa (girl in my avatar) she's the easy one to spot - I'll be the tall guy close by.
