I dont see any images.
The Car : Ford Focus Zetec 1.6 Hatchback Reg 2003
At last after 18 years of Company Cars I had my own car which I could do what I like with…..and what I really wanted to do all this time was “PC” it.
EDIT: Be sure to check out ALL the pics this install is in two phases.
Another little gadget added 15/3/2005
Roof Flip Screen added 4/4/2005 see set of Pics![]()
Removable Sun Visor added 9/4/05 Just need the sun now to try it out![]()
Tints added 26/4/2005 to compliment the sun visor See Pics
Reversing Sensors added 14/12/2005
Disaster results in Upgrade added 23/01/2007
New Reversing Camera added 3/04/2007
New Removable Sun Visor added 19/4/07
New Mobo & PSU added 11/5/2007
Happy to try and answer any questions on this install![]()
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
Osiris Networx
--Tuning is all about price vs performance. You've got to find your own medium.--
The Kit : Having researched a while I came up with the following:-
Morex 3688 case ; Epia M10000 motherboard : 512 meg ram ; Slim Samsung CDRom ; 40gig Fujitsu laptop hardrive ; Ituner ITPS car power regulator ; BU-303 usb satellite receiver ; Mercury 801b WiFi card ; Lin-ITX 7in. 16:9 touchscreen VGA monitor.
The satellite receiver is positioned in the nearside corner of the dashboard.
And the Wi-Fi card in front of the rearview mirror.
Initially the touch screen was mounted on the dashboard on a mounting that consisted of a special Focus bracket and part of the fitting from the small stand that was supplied with the touchscreen
In the next photo’s you will see that the touchscreen was made detachable for security reasons. This was OK but became a bind when it had to be removed each time I parked, and so facia mounting was a future option I was seriously considering
Pretty sweet and basic install. I like it.
Osiris Networx
After a few months using this install I decided to take the plunge and try a facia mount. For this I needed to buy a 2nd facia panel which I could adapt to take the touchscreen, leaving the original one intact to replace if I came to sell the car.
Because of size limitations it became clear that I needed to remove the touchscreen casing and mount the screen and electronics directly into the facia. The next few photo’s show the progress of that project.
A plastic moulding to take the screen and electronics was made for me by a friend. The facia panel needed a bit of dremeling on the lower edge to accommodate the depth of the moulding which in turn was the depth of the screen.
Plastic ties are not just for retaining wheel trims !
A control panel with push buttons needed to be built into the plastic moulding because the original was part of the case.
And some photo’s of the screen in use.
