Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: '99 Ford Explorer first carputer
    Newbie thrice's Avatar
    Mar 2004
    Arlington, TX
    just begun installing my carputer, starting with the screen. i don't have much to show as of right now, as i've only worked on it one day, and i'm an idiot and didn't have my camera with me during that first day. it's a pretty basic install. all i've really needed to get to where i am now is bondo, dremel, and sandpaper. still needs some sanding, and touching up, but i think it's a decent start. let me know what you all think so far. again, sorry for the lack of before/after pics
    http://www.ipwnj00.net/carputer/side.jpg
    http://www.ipwnj00.net/carputer/bottom.jpg
    http://www.ipwnj00.net/carputer/front.jpg
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    looks gooood!!! keep up the good work :-D i got a 94 explorer check out my page... www.explorer.aajanachle.com -- soon to do a navigator or esclade conversion!!!
    Mar 2004
    Arlington, TX
    thanks dj. i like your setup, very nice.
    here's some more pics of the dash. pretty much done with it now. only thing i have to do now before i can put it in my car is clear out the screw mounts in my car that get in the way of the screen. it's not perfect, but i'm definitely happy with the result
    http://www.ipwnj00.net/carputer/100_4292.jpg
    http://www.ipwnj00.net/carputer/painted.jpg
    http://www.ipwnj00.net/carputer/painted2.jpg
    http://www.ipwnj00.net/carputer/finished.jpg
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    nice.. I have a 98 X .. I'm thinkig of doing the same you have.. right now it's just press fitted.. greta for debugging.. but I've got most of the kinks worked out..
    however I moved my head unit to that space in the bottom.. and my AC controls to the bottom center console.. ..
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    looking pretty good ... I'd suggest sanding it down a bit more and really work the feather sanding around the corners. you can see where the bondo stops and the plastic starts. with enough feather sanding you can get this to be seamless.
    also the picture may be misleading but I think you could get a smoother finish on the paint if you did it in multiple light layers sprayed from a distance, and wet sand with some super fine grit paper between coats. (did you use primer at all?)
    looking good though!
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    Newbie Kalavera's Avatar
    Jul 2003
    Ireland
    Nice work with the dash. Should look well when installed. Keep up the good work.
    PS. Should this be in worklogs? Just a question, I don't want to ruffle any feathers.
    Current Cfg: AMD 2200+, Epox Mobo, 7" Lilliput TS, 320MB RAM, 40GB 2.5" HD, 200GB SATA, Slim Combo, ATI Radeon, SMC B/G Wireless w/ 5dB antenna, Bluetooth.
    S/W: RoadRunner/MapMonkey/NetStumbler. Still working on a box and PSU!
    Mar 2004
    Arlington, TX
    thanks for the suggestions. i think i may go back and feather sand it.
    i've never noticed the worklogs forum. sorry about posting here. would a moderator be so kind as to move this to the worklogs forum?
    Mar 2004
    Arlington, TX
    i went back and sanded it with 600 grit sandpaper and applied a couple more coats of paint, sanding in between. definitely made a difference. here are a couple pics of it in my car and ghetto rigged to a laptop i had lying around.
    http://www.ipwnj00.net/carputer/indashfar.jpg
    http://www.ipwnj00.net/carputer/indashclose.jpg
    let me know what you think
    Oct 2003
    Atlanta GA
    hard to tell exactally but looks like the extra sanding and paint made a big difference. looking good.
    My JeepPC Install
    Low Bitrate Sporttracguy's Avatar
    Jul 2004
    Puyallup, Washington
    Looking good,, very similar to the install i did,,i used the xenarc though so it took more cutting to fit the larger xenarc case in there
    2 LCDs 2 touchscreens sport trac, check it out
    Sporttracguy
    Here are some shots of my ride, be sure to scroll all the way down:
    http://www.cardomain.com/memberpage/674459
  1. 1994 Ford Explorer XLT CAR PC - LOTS OF PICS!!!
    By xdjxklusivex in forum Show off your project
    Last Post: 09-04-2009, 02:07 PM
  2. 96 Ford Explorer Premium Audio System Advice
    By tczbu in forum Car Audio
    Last Post: 04-13-2008, 08:37 PM
  3. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  4. Carputer install in the Ford Fiesta 2003
    By skyflyer in forum Show off your project
    Last Post: 07-08-2006, 11:41 AM
  5. MACH stereo in Ford Explorer
    By seven10split in forum General Hardware Discussion
    Last Post: 07-11-2005, 03:59 AM
