Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: 98 Volkswagen Passatputer
  1. #11
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    you wouldn't belive, but it's actually pretty good. I thought i will be suffering from "oomphness" but not that bad. It's slow on boot (i didn't measure it yet) but once it's in there, it's ok. My only problem right now i that i have to go to the back when turning it on. The opus is acting up, or maybe i wired it wrong. BC when i plug it in it automaticly turns on, even if the is off. I plugged a lead from the back of the stereo, that tells the AMP when to turn on. so i think it should be like whenever i turn on the stereo the amp and the pc turns on, and the same to off. Anoter thing is, that when i shut it down, XP sas it's safe to turn off the pc now, and nuttin happens. any solutions?
  2. #12
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    cool.
    As for the problem, is the bios power management set right?
  3. #13
    Aug 2004
    Walden, NY
    I'll check that... another problem. with the hitty roads around here and all the bumps, the videocard slides out of the AGP slot. have to find a way to mount it there. maybe ill se some god ol' Priority tape...
  4. #14
    Mar 2005
    Tyler, TX
    Did you wedge the stock Xenarc stand in the AC control?
  5. #15
    Aug 2004
    Walden, NY
    Quote Originally Posted by domisi
    yes. i will eventualy mount it indash, but i need to get a double din bazel and brackets to it. that has to wait for now...
  6. #16
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by BoyNextDoor
    I have the Ignition wire from the Opus wired the same way, and it's working fine...I think your problems may be caused by the mobo, how old is it?
  7. #17
    Aug 2004
    Walden, NY
    well it's a noname P3 mobo... i ave no idea how old it is...
  8. #18
    Romania
    Older mobos didn't have auto turn off function, so after you pressed turn off, the windows would close, but in order to turn off the computer, you would've still needed to press the button. Maybe this is how yours is too, since it won't turn off, keeping in mind you've made all the BIOS and Windows setting correct.
  9. #19
    Aug 2004
    Walden, NY
    i think i have to bite the bullet and get the amd setup i wanted... darn...
  10. #20
    Nov 2004
    Nice work man, passat carpc install in NJ.. I swear we're twins.
  1. Windows 98 / Touchscreen problem.
    By ddt in forum Input Devices
    Last Post: 06-04-2004, 09:09 PM
  2. 98 Lite and 5.1 sound ???
    By Lando in forum General Hardware Discussion
    Last Post: 10-26-2003, 07:22 PM
  3. win 98 SE
    By cubanmoses in forum Software & Software Development
    Last Post: 08-15-2003, 09:34 PM
  4. Networking 98 & XP
    By Rob in forum Off Topic
    Last Post: 09-02-2002, 02:24 AM
  5. DVD and CD burner dont work above win 98
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-09-2002, 07:56 PM
