How is the keyboard mounted? Detachable?
Where'd you put the computer?
2004 Subaru Impreza Outback Sport Carputer Install
Not a WRX like so many other installs, but for the purpose of a carputer, it might as well be. Anyways, here is my rendition:
*******UPDATE********UPDATE********UPDATE*****
Ok, tons more pictures after many many more hours of work, moving entire setup to spare tire well, cleaning up setup, etc. Have a look:
USB2.0 Dock in clock pod, 2 ports on top for on the go plugins! (i.e. thumb drives, network adapter, etc.)
super troopers!
receiver for gyration keyboard/mouse
super troopers!
amp in trunk (that install took so long...but i finished way before starting carputer project)
Scroll Down about 16 posts for more Pics!!
OLD PICS:
Questions?
Keyboard is mounted with velcro so ya it is detachable. Where it is mounted it is perfect for passengers, but when I am stopped I can easily put it on my lap.Originally Posted by Zaffir
The computer (laptop), wires, etc. are all under my passenger seat.
GPS is on the dash in the right corner.
I haven't mounted my dvd drive yet, so right now only a cd drive.
nice basic and clean straight to tha point good stuff keep up tha godo work!
CarPC Status:
Hardware: 100%
Software: 100%
Case Install: 100%
Dash Install: 100%
Car Install: 100%
crap factor: 100%
new carpc finished, thinking of way to mount HDD
and not installed yet.
right now the laptop is powered through a cheap-o inverter. though since i will need to plug in at least two more ac items i will be changing my power setup in the near future, i am just not exactly sure what to do, even after countless hours of reading the forum and doing searches.
my sound is just a 1/8"male -> dual phono --> rca cable that goes to my eclipse amp that is custom mounted in my wagon floor, which then powers mb quart premium components. sounds beautiful.
another problem i am having is i cant use my ipod right now because for some reason it isnt being charged while plugged into its usb2.0 slot, so it dies on me super quick.
any ideas?
are you running your usb2 from the boot? if the cable is too long you are probably losing power.... - batteries charge from amps, not volts, and if the cable is too long the usb wont be able to output the right power through it - also do you have any direct control over the audio volume, not the windows control?
CarPC Status:
Hardware: 100%
Software: 100%
Case Install: 100%
Dash Install: 100%
Car Install: 100%
crap factor: 100%
I am going to be getting a powermate as soon as I go to the mall, but for now i just have the windows control and volume buttons on my keyboard, (inconvenient for quick mutes/changes)
My usb 2.0 is just a pcicard or whatever its called that goes into the side of the laptop. Then my iPod plugs straight into that, so i doubt it is a length issue. the only thing i can think of is that when i bought my usb 2.0 card, some of them had a power adapter and some didnt. mine didnt. that is probably it, i just figured that since it didnt it would draw power through the laptop...?
i really need help figuring out how to deal with all these power issues, i have at least 3 ac items i need to get power to somewhere/how.
Thanks for the replies/help.
most likely your USB card is not self-powered w/o the ac adapter. I have run into the same thing on USB hubs. They work w/o the AC adapter but won't charge unless plugged in.
Also, there are some internal USB ports (typically on the front of a PC and totally thinking desktop here) that are also no able to charge devices.
