Results 1 to 10 of 17
Thread: Vw Golf Mkiv Install
    Feb 2005
    After Along Time Of Playing Its Finally Inn
    Spec
    Epia-ml8000a
    256 Ddr Ram
    40g 7200 Hard Drive
    M1atx Power Supply
    Rikaline Gps-6010
    Bluetooth Dongle
    Lilliput 7" Touch Screen
    Bezel Made From New Center Console With Replacement Lilliput Bezel Molded Inplace With Fiberglass And Body Filler.
    Heres The Pics
    Low Bitrate LordSnow's Avatar
    Jan 2005
    Louisville,KY
    Nice install....bezel looks awesome. How about some pics of the PC?
    Oh, and did anyone ever point out to you that your steering wheel is on the wrong side? ...because it is.
    Feb 2005
    Quote Originally Posted by LordSnow
    LOL, I couldn't imagine trying to shift with my left hand ...
    Feb 2005
    changing the steering wheel side was the first car mod that i did!!!!!!!!!!!!!!!!!!!
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    No way I could ever shift with my left hand...
    Like someone said, how about some pics of the actual PC? (Please. )
    Feb 2005
    will sort some out this afternoon
    Feb 2005
    carputer
    heres the pics of the carputer. mounted on two bits of mdf . this is a temp install as i built this for a friend for his astra. so the bezel i made will be for sale if anyones intested.
    Mar 2005
    NICEEE..
    I can't wait to do this to my 2002 Golf. Trying to decide what parts to buy first.
    Anyhow, where are the AC controls and such? Close-ups? I wish there was a detailed description on what wires to use and all. Is it possible to not take apart the dash to atleast disconnect the stock tape-deck and connect the screen with a stand? (going to fiberglass in June)
    Mar 2005
    Ah, another thing... volume. What's the best way to connect it all up to the stock speakers in our Golfs?
    Low Bitrate Man Ace's Avatar
    Mar 2005
    Seattle
    Quote Originally Posted by zomb
    Unfortunately, if you have a monsoon vw system it is a little tricky. R32Juhl Figured how to send the signal straight from the comp to the monsoon amp by supplying the amp a 5V signal with the comp input. Read his thread about it. I am currently waiting for a write up on it first before I decide what I should do.
    Otherwise you can get an Aux adapter that turns the CD changer plug in the back to an RCA so you can hook up the comp soundcard.
    My dilemma is to keep the stock headunit and get a single din or to remove the HU and go with an in dash screen. I don't want to get rid of my AM radio though. So it is a little difficult for me to deicde. Also the thought of someone stealing the screen scares me too if it is plain view.
  1. MKIV VW Jetta Install v2.0
    By ppgt94 in forum Show off your project
    Last Post: 04-28-2007, 05:40 PM
  2. VW Golf V6 install
    By Matthew230 in forum Show off your project
    Last Post: 10-07-2006, 07:35 PM
  3. News about a MiniMac Install in a VW
    By bergeron76 in forum MacCar
    Last Post: 03-13-2005, 04:23 PM
  4. Replies: 14
    Last Post: 03-10-2005, 05:02 AM
  5. VW Golf V TDI Carputer install
    By drib in forum Show off your project
    Last Post: 12-27-2004, 01:41 AM
