Results 11 to 20 of 27
Thread: VW Golf Mk 3 III
  1. #11
    Mar 2006
    UK
    Thumbs up
    Well done, that is a nice clean looking install
    I have a couple of questions:- How did you get the texture on the centre console?
    And do you find the position that you installed your screen too low while driving, or is it just right?
    Thanks.
  2. #12
    Newbie bunter's Avatar
    Feb 2006
    West Midlands, UK
    I was also going to put a screen there, but it doesn't seem right. A bit too low for my personal taste (don't get me wrong, yours looks very tidy) but just not for me.
    I think i am going to put my blower controls in the cd player slot since i plan on removing it all together, then fabricating the screen in their place.
    (>'.')> Dance Kirby! Dance For Me!! <('.'<)
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    sweet!
    and in a MKIII none-the-less!
    I like!
    Jan Bennett
  4. #14
    Mar 2006
    UK
    Quote Originally Posted by bunter
    I was thinking the exact same thing, as I wouldn't miss the centre vents much.
    I'm just trying to figure out the best way to match the texture of the stock Mk3 dash though...
  5. #15
    Tainted Love Cris's Avatar
    Romania
    That looks great!
  6. #16
    May 2003
    Germany
    Ups... there is activity after one year here
    A friend of mine is body painter (varnisher? right word?). He did the final painting job. I think it would be best to ask at a local painter's shop, because they've got the right varnish for this (there are particles inside, that build the pattern on the surface while drying). I've never seen this stuff in a shop, but a varnisher should sell it to you (or do the job for you). I hope this helps you atleast a little...
    The position... For me it's ok. I'm sitting quite low and the display is looking right to me. So I nearly never get problems with reflections or sunlight. But your absolutely right, you have to look DOWN. So it's a good idea to think about it for some time . The most used funktions can be used via my steeringwheel remote conrol. Hmm... Looking back, I never ran into ANY problems due to the display's position in all the time. And you know how fast we are going on our Autobahn
    I made some plans, to put a little 3" oder 4" display for navi output where the left upper speaker is. But at the moment I'm thinking about buying a different car some day and blablabla So things will stay like this...
    Bye Joerg
  7. #17
    Constant Bitrate reiner15's Avatar
    Mar 2005
    Michigan
    nice nice nice install man
    i did a google for the battery you used but found a ton of results... could you tell us where to purchase it?
    My Site: http://www.reinerweb.us
    My Car : http://members.cardomain.com/reiner15
    Car Computer Alias - TekPC
    Current Progress - - Brainstorming
  8. #18
    Newbie sirpilsofd's Avatar
    Apr 2006
    New Jersey
    Is it any old 25Ah battery we can get our hands on or are there specific types? And the device that is used to seperate the car battery and the "big block" the one at the bottom of the pic with only one terminal connected. I am guessing that the other terminal connects to the positive terminal of the car battery right?
  9. #19
    May 2003
    Germany
    Ahh sorry... I was on vacation... (my head is SO burned )
    Yep, it simply is a gel battery (so I can use them inside the car). You are also right about the other terminal. It's for plus from the front battery.
    The device is a big relay (90A and 150A peak). It's only so big, because the amp could pull alot and the smaller ones didn't have adequate terminals. The battery itself should never take more than 10 or 20A, even if it's empty. But please measure it and don't forget that you might need to make the fuse smaller, so the cables and the relay are protected.
    The relay is switched by D+ from the car's generator. This pin gives 12V when the generator is powering the car. This way the batteries are disconnected until the car is runnig, so the carpc doesn't suck from your front battery and the crankingmotor doesn't touch your carpc's battery.
  10. #20
    Apr 2006
    New Jersey
    Krog thanks for the clarification.
    N00B
  1. Replies: 268
    Last Post: 08-19-2007, 08:53 PM
  2. VW Golf mk3 - carputer project
    By Sh0cker in forum Show off your project
    Last Post: 12-09-2005, 10:14 AM
  3. Replies: 14
    Last Post: 03-10-2005, 05:02 AM
  4. Golf III?
    By erazor in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-14-2004, 09:55 PM
  5. VW Golf IV multimedia-car 2002
    By Fluffy in forum General MP3Car Discussion
    Last Post: 11-14-2002, 08:00 AM
