Results 1 to 9 of 9
Thread: 93 Lexus sc400
    Apr 2005
    USA
    93 Lexus sc400
    Completed my project and I'm pretty satisfied. There were a few digressing moments but overall it was pretty plug-n-play. I did this because I like my SC a lot but also like my techy toys too. Doing this allowed me to kind of have best of both without shelling out LOTS of money.
    The total cost of the project was about 1,250 include system, monitor, connections, etc. and I feel it was worth it. I already had a copy of the software so I'm not including that here.
    Hardware system includes:
    512MB DDR Memory,
    100GB Hard Disk,
    internal CD/DVD,
    external slotless cd/dvd usb powered
    TV out, 5.1 Channel Audio
    Chipset - VIA CLE266,CPU - embedded VIA C3 Nehemiah 1.2GHz CPU
    10/100 Ethernet Integrated Video/Audio,
    4 USB 2.0, Card Bus and Compact Flash slot
    Xenarc 700TS
    sharkradio am/fm
    I already had wireless PCMCIA and a garmin gps head unit, 200 watt amp, and XMPCR
    computer size is 8.25" x 10.75" x 2.5", which fits nicely under passenger seat yet allows seat to still function 100%
    Software includes:
    WinXP, Routis GPS, and Media Engine
    Installations:
    The stock SC stereo head unit, cd player and amp were removed. I then determined the angles required to modify the shell clam for the Screen, taped off, checked twice, and using a hacksaw proceeded to cut the sides off the front half of the casing. This allows it to sit recessed in the console but also fit snug on the sides. Overall it looks more professional then most installs and does not move or rattle. I find that the morning sun coming in from the rear window does effect viewing but then I don't have any tint on my windows yet.
    The computer was mounted under the passenger seat and fits quite well. The seat can still move all the way forward and back without touching the computer. Nobody can really sit in the back seat of an SC so I'm not too worried about that but if needed, they could. All lines for power and monitor run under the carpet to the center console and then to appropriate connections. The XMPCR and Garman serial cable runs under the carpet and then under the seat and the head units sit on the back dash in the corner. The XMPCR has a black box that satellite receiver plugs into and then an audio and usb cable run back to the computer. The rear cushion of the SC completely takes up the space under the seat area so this black box was slid up behind the back of the rear seat where there is a pocket of cushion large enough to hold it in place.
    I went to different local auto parts stores and found the proper Toyota stereo connection (on 3rd try) to us to connect to the set of wires that use to run out of the amp to the Speakers. It also carries ground and trip wire so all I really needed to do was find another constant 12 volt to amp. I could not figure out how to wire into the second base amp the SC uses to drive the 10" woofer but I'm going to upgrade now that it all works to a 5 channel amp and new speakers so it will not matter.
    I installed the mat****a-panasonic cw-8124-b, which is an external usb powered, slim, spotless unit in the glovebox so it's out of the way but still can be reached if neeed.
    I installed the sharkradio and (sorry griffin) it basically sucks for automotive application. Had to move it all over the car to determine best reception and currently sits in sun-roof area. I'm in the middle of converting a 120v 50-2000htz amplifier to 12v and see if I can incorporate it to improve the signal level enough to be satisfactory. I understand they have an external antenna jack, bla, bla, but it's just too weak, even tied into the stock car antenna. If they would improve it's reception they could have a winner.
    I also purchased the powermate control knob from the same company and this is pretty cool to control volume/mute,etc.
    Yet to do....
    Connect cell phone to PC for mobile wireless internet -- I already have this working for my laptop and PDA so it's a no-brainer.
    See if I can replicate it all in Linux -- I'm a UNIX die hard.
    That's it. here are some pictures...
    Jun 2004
    Orange County
    You in irvine? I used to work right off Alton...
    Anway, why didn't you get the TSV? The TS doesn't have touch screen capability does it?
    Glad to see another carputer in a SC...
    Here's mine:
    I fit everything behind the screen minus the hd mounted outside. Working on a version 3 which will have the screen sunken like the newer Lexus'...
    I molded mine up top because our huge shifter gets in the way of the rear passenger's views.
    ps..don't mind the dirty *** mats..haha...my restoration project is moving verrry slowly...
    Lexus SC400
    Subaru WRX Wagon
    Apr 2005
    USA
    yea, south county area.
    ts is touch screen the 'v' has video input for movies. This is something I didn't need cause I like my couch for that.
    Boy you did a lot of work but looks cool and unique.
    Illinois
    smoking is bad...mmmkay
    Nice car and setup. Did you do anything to fit the screen in there, or was there just enough room?
    Apr 2005
    USA
    last of my vices -- and the toughest too.
    Had to trim about 1/4" off each side of the front half of the 'clam shell'. This turned out to leave the exact depth I needed so that it remained flush with the rest of the dash and look like it belongs -- I installed it from behind. It also provided a snug fit so the monitor is naturally 'held' in place and works well.
    Depth is OK with about 2" to spare. no real modifications or contruction to make it work so I would consider it a plug-n-play situation.
    side note.. I first masked off with tape the tapered angle of the dash onto the shell. Then I used a hacksaw to cut the shell very slowly so I had a clean finish. After installing, my straight cut pointed out that not only did the dash section taper in (getting smaller and you moved down--- \ / ) it also has a slight bow to it -- ( ) that I had not noticed just looking at it. This left the shell tight at the top and bottom but a slight gap in the middle. something I notice but others have not. hope this all makes sense.
    Apr 2005
    USA
    If you look at the xm picture closely you can see what I'm refering to about the gap.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Hi! Great looking install
    I'm doing practically the same thing, except I'm getting rid of the A/C controller. Don't need it since its broken and expensive to fix. I'm going with it being computer controlled... check my sig
    Also, do you get any glare?
    Apr 2005
    USA
    Hi, you're the one that 'inspired' me to move forward in the direction I did. I wanted to keep it as stock as possible in case I traded my car in for another SC. This way I could put all the stock stuff back in and install in newer 400. I understand about the a/c unit and did you know there is a company who will repair it for about 300? also keep ebay in mind as I've seen them there too.
    Yes I do get glair but I also do not have any tint on my windows. I happen to drive west in the morning so it comes in thru the back window. It's really not that bad and I also opted to change the media engine skin to cnsskinoonw which takes better advantage of the screen, it darker at night, and bigger buttons.
    Keep us posted on your project and good luck.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by meinoc
    Thanks for letting me know that I was your inspiration
    Trading your car in isn't wise... you'd get better value by selling it yourself.
    I don't really care about the A/C. I still wouldn't have any space for it.
    I hope that glare isn't going to be a huge problem for me
  1. Lexus Nav. Software
    By muldrick in forum Software & Software Development
    Last Post: 06-03-2007, 08:02 PM
  2. 98 Lexus GS300
    By chunkymonkey909 in forum Show off your project
    Last Post: 03-08-2005, 03:58 PM
  3. Lexus IS200 Car PC Advice and Help!
    By Anees in forum Newbie
    Last Post: 03-02-2005, 12:31 PM
  4. Lexus Software
    By muldrick in forum GPS
    Last Post: 08-10-2004, 12:29 PM
  5. Lexus Touch Screed
    By jmack in forum General Hardware Discussion
    Last Post: 10-29-1999, 11:42 PM
