Results 21 to 30 of 32
Thread: 2004 Chevy Impala Carputer
  1. #21
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    nice car, I would suggest tucking that wire or find another spot
  2. #22
    Low Bitrate c4shm0ney's Avatar
    Jul 2004
    Indianapolis
    Nice install. How are you coping with the glare?
    01 Metro LSI
    79hp 41MPG Highway
    Check my progress
    http://www.mp3car.com/vbulletin/worklogs/51295-01-metro-lsi-4-door.html
  3. #23
    Nov 2005
    I have a 04 Impala and wondered it you ever investigated replacing the stock stereo with the 7" screen? I have not measured mine yet but it seems like it would be a close fit.
  4. #24
    jlg
    jlg is offline
    May 2005
    I will be putting the screen in place of the factory radio in the spring. It looks like it should be a close fit, but some cutting will be needed. The radio needs to be relocated to the trunk because some of the cars features are controlled by the factory radio. There are harness kits available on the net that will extend the factory harness all the way to the trunk.
  5. #25
    Sep 2005
    just fyi- I haven't read through this thread to see if it's been mentioned but...
    your GPS antenna that you mounted on your trunk has a wire connected to it that goes into the trunk... that wire would act as a perfect track for water to run down. From there the 'drip point' would be right on to your amp.
    just a head's up.
    nice setup btw.
  6. #26
    Nov 2005
    Thanks jlg. I had never heard of the relocation harness. I will definatly check it out. I plan on placing my screen in the same place in the spring or earlier. Whoever doe it first should communicate our problems.
    Also, since you are using the stock radio. How are you directing the audio? Throuch a FM Modulator?
  7. #27
    jlg
    jlg is offline
    May 2005
    Quote Originally Posted by bagwellfive
    just a head's up.
    nice setup btw.
    I have been through car washes and heavy rain falls since the install and I havent had a problem yet. Thanks for the heads up though, I will keep an eye on it.
    Quote Originally Posted by Edgecrush_TD
    The audio comes in through a auxillary input adapter made by PIE electronics (Part #GM12-AUXv2). It turns the input on the radio for the optional 6-disc changer into standard stereo jacks. I press the 'band' button on the radio a couple times to bring the radio to the aux input. the sound quality is great.
  8. #28
    Nov 2005
    I completed all the necessary measuring and your 7" screen will fit in the dash hole. I'm hoping to get mine in soon.
    I have a LCD mounting plate I'm designing. I'm having it machined within the next few months. I'll get some pics of the design up soon. If your interested enough I can see if I can get 2 made at the same time.
  9. #29
    Constant Bitrate thunderdepot's Avatar
    Sep 2005
    Is this the one you bought? Do you like it?
    http://www.cardomain.com/item/POWGOOSE22
  10. #30
    Nov 2005
    Here are some pics of what I have been working on. The assembly is for a Lilliput 7 incher I have.
  1. Aux Input for my 2004 Chevy Colorado
    By soquickwitit in forum General Hardware Discussion
    Last Post: 08-03-2005, 01:33 PM
  2. 2004 Hyundai Tiburon Carputer In Progress
    By bjm2020 in forum Worklogs
    Last Post: 05-24-2005, 09:03 AM
  3. GPS Navigation suggestions 2004 Impala
    By dmorlow in forum GPS
    Last Post: 04-30-2005, 04:29 PM
  4. Newbie with 2004 Impala
    By Qwerty in forum Newbie
    Last Post: 02-04-2005, 06:35 AM
  5. My Chevy Tahoe and carputer
    By reggiek945 in forum Show off your project
    Last Post: 05-24-2004, 11:13 AM
