Results 11 to 20 of 24
Thread: 2001 Jetta CarPC Worklog
  1. #11
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    nice car.
  2. #12
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Quote Originally Posted by Dillusion
    I dont see a worklog section? All i see is fabrication, and thats quesitons about materials. If a mod wants to move this, thats cool. Itll be finished in only a few days tho
    Cool. Just for future reference, when you click on the "Show off your project" forum, look near the top of the page for the Worklog subforum.
  3. #13
    Newbie Dillusion's Avatar
    May 2005
    Yeah im blind, im on forum networks all the time too, just didnt see it.
    Updated my agenda for tommorow!
    100% DONE!
    tVIEW 8" 8x6 LCD
    EPIA800
    2x128 PC133
    10.2GB HD
    Audigy Gold + Bose Speakers + Sony CDXM880 HU
    2001 Jetta CarPC Finally Done!
  4. #14
    May 2005
    Ok heres the pics from Friday/Sunday..Heres a short problem list:
    -EPIA wont boot from RCA, doesnt detect 8" LCD as a monitor.
    -Sanded down corner of audigy btu shorted it out.
    -Harddrive gets too hot (Turned fans around)
    -Computer didnt fit under dash (Moved under seat, see pic)
    Problems im still having:
    -Inverter goes into protect mode when car starts, need to hardwire it...?
    -Going to us a VGA to RCA cable isntead of trying to make the RCA cable itself work...
    Onto the pics! (BTW, everythings installed, just waiting on VGA adapter and hardwire battery)
    All installed, cleaned and washed!
    The wireless USB adapter is in the corner of the dash still, the wires are hiden under the floorboards on the side...all the wires for the computer are hidden inside the center console and wired on the side into the Headunit/AC harness where they plug into the HU/LCD.
    100% DONE!
    tVIEW 8" 8x6 LCD
    EPIA800
    2x128 PC133
    10.2GB HD
  5. #15
    May 2005
    5/18/05:
    Soldered PWR/LED into mobo
    Fixed Inverter Protect problem
    Hooked up everything but LCD
    I will have pics of the unit working by the end of the week! Now lets hope my battery doesn't die.
    Heres a little rear end action for hits:
    100% DONE!
    tVIEW 8" 8x6 LCD
    EPIA800
    2x128 PC133
    10.2GB HD
  6. #16
    Newbie ErikArmbrust's Avatar
    Apr 2005
    Nebraska
    How come you want to hook your VGA monitor up to RCA's? that doesn't make much sense, because the signal quality is going to be bad... and you won't be able to read text very well at all. You should stick to S-video or the vga input, unless you don't care if you can't see anything on the monitor.
    Finished carputer:
    2000 Black Blazer
    Construction/ finished/ before
  7. #17
    May 2005
    My monitor is RCA, so i get bad quality from the bat im only using a VGA to RCA adapter because windows defaults to VGA display every restart because it cant detect the LCD by itself, so VGA to RCA adapter is in order.
    100% DONE!
    tVIEW 8" 8x6 LCD
    EPIA800
    2x128 PC133
    10.2GB HD
  8. #18
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    I think you just have to short some pins with a resistor on your VGA out on your board.. try searching, you may be able to return that adapter.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  9. #19
    May 2005
    Yeah the adapter was only 8$ neway, who cares. I read that thing about the pins, and it looks too complicated for what i need to do.
    100% DONE!
    tVIEW 8" 8x6 LCD
    EPIA800
    2x128 PC133
    10.2GB HD
  10. #20
    May 2005
    Chico, CA
    Why bother with the Sony headunit? Why not just run the audio out through the Audigy? You'd probably get better sound anyway.
    Looks cool, though, man. Like the 802.11g adapter. Was going to do the same thing, if I build mine... You could also use a USB stick adapter, if you wanted to conceal it.
  1. 2001 VW Jetta CarPc Install
    By *Glow* in forum Show off your project
    Last Post: 03-27-2008, 04:00 PM
  2. Worklog: Wasabi's 2001 VW GTI VR6 Carputer
    By Wasabi in forum General Hardware Discussion
    Last Post: 10-08-2005, 02:11 PM
  3. 2001 Corolla CarPC Done!
    By Deadnick in forum Show off your project
    Last Post: 01-20-2005, 04:33 PM
  4. 2001 BMW 323i CarPC project
    By febsperanza in forum Show off your project
    Last Post: 01-06-2005, 12:09 AM
  5. Need help for a carpc in 2000 jetta
    By Xc0m in forum Newbie
    Last Post: 07-05-2004, 02:22 PM
