Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: (AUS) BMW E36 Extensive Customisation
    CAA
    CAA is offline
    Low Bitrate CAA's Avatar
    Mar 2005
    AU, VIC, Altona
    Talking (AUS) BMW E36 Extensive Customisation
    Hey guys been reading these forums for a while whilst putting together my carpc.
    Here is some info... and some progress shots of the dash and 12" Touchscreen to date. Its all off at the trimmers at the moment, so once it gets back I'll post updated pics.
    The system is still effectively built for Sound Quality primarily, but will be completely controlled from a CAR PC system that I have built up and am still in the process of finalising.
    To start with a 12" touchscreen LCD screen is being grafted into the dashboard in place of the aircon/heater controls, headunit and previous place of the navigation.
    This screen drives the entire audio / navigation system and other computer controlled interfaces. Essentially it is Windows XP stripped down of non-vital components and running a customised version of Media Engine designed for CAR PC applications.
    The computer is a P4 2.0Ghz with onboard video, lan etc, with a 60gb HDD (for XP) and 200Gb slave drive. My Blaupunkt Navigation inputs into the computer and outputs also on the PC screen when required. I'm also running wireless networking to be able to update the CAR PC from inside the house.
    From the Sound Blaster Audigy sound card we have a digital signal feeding into the Precision Power external DAC. This converts the high resolution digital signal back to RCA's and then into an Audiocontrol MVC to allow analog volume control.
    The on to the rest of my audio setup which includes the existing horns in the front, along with Dynaudio 8" mids up front (soon to be installed).
    I'll keep this updated
    But if you want more information:
    http://www.caraudioaustralia.com/for...3&page=1&pp=20
    and
    http://www.caraudioaustralia.com/for...d=299&garage=1
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Your links require that I register, and your pics are broken cause I'm not registred... cant you repost it all here? I dont feel like registering for yet another forum
    CAA
    CAA is offline
    Mar 2005
    AU, VIC, Altona
    Sorry about that... have attached images instead.
    São Paulo, Brazil
    can you repost the description from the link maybe?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    The steering wheel is on the wrong side
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    damn thats a big screen, gonna be sweet when it's done
    肚子笑痛了
    S60 Install
    CAA
    CAA is offline
    Mar 2005
    AU, VIC, Altona
    Quote Originally Posted by 0l33l
    Hahaha
    Don't know if I pointed it our above, also using an Opus 150 Power Supply, and running Frodoplayer.
    The rest of the audio system is pretty high end also.
    Verita's HLCD's up front (evident in the picture with the dash out), Dynaudio 8" Midbass in the kick panels.
    2 x Diamond Audio TDX 12" Subwoofers, running off 2 x DD M1 Monoblocks (strapped) as well as 2 x Diamond Audio D7 Reference Amps for the front stage.
    Australia's Largest CARPUTER Discussion
    www.carputer.net.au
    São Paulo, Brazil
    Cool, how does your GPS feed into the computer??? Or does it just fit into an extra vga or composite input on the screen?
    Also, are you having any issues with the P4 2ghz and the opus 150?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    WOW! on the dashboard remove. I am not brave enough to do anything like that. But then mine is used daily
    May 2004
    Northridge CA
    wow that first pic gave me chills
  1. Enforcer's BMW E36 Carputer 1
    By Enforcer in forum Show off your project
    Last Post: 07-11-2011, 10:27 AM
  2. bmw e36 obd II to car pc ?
    By koko in forum Newbie
    Last Post: 01-03-2008, 02:58 AM
  3. BMW E36 Limo
    By mmstudios in forum Show off your project
    Last Post: 08-30-2005, 11:08 AM
  4. How to remove plastic parts on a bmw e36?
    By darkdiamond in forum Newbie
    Last Post: 03-02-2005, 11:18 AM
  5. Carputer on a BMW E36 Cabrio
    Last Post: 10-11-2004, 03:24 PM
