Love the carputer "case". Turned out awesome, I think I might do something like that in the Focus... Blends in nicely.
Nice install
I have the EXACT same car, color, etc. but 2005
I put the computer up in the trunk between the two speakers, but mine is much smaller (M1-atx + epia m10000). I'm waiting to install the monitor..
Nice to see some rolla s owners![]()
Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
Trunk fiberglassing in progress...
Need GPS / Aux Input / WiFi
My Corolla Computer
You did the screen mount yourself ? What did you used ?
My Corolla Computer
scott - no 4x4ing for mealthough my car does smell nice because of that thing, hehe (good ol' glade car freshner)
thanx rs3rs, that thing was a pain in the butt 'cause of the rounded molding in the trunk... lotsa cardboard cut outs to see if it fit, then cuttin the wood. but luckily, i found a craft store that had a fabric that almost exactly matched my trunk~!
CapitaineFritz - it's just a cut up lilliput.. I basically bought a scosche single din stereo adapter, and dremeled it to hold the lcd. then bondo'd the piece to be smooth. i can post a more detailed blurb if ya want
90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
My Install
is the Optima a 2nd battery to power the computer only? I was thinking of doing the same. If you did add a 2nd battery, can you post what you used?
Lexus SC400
Subaru WRX Wagon
bulgogi777 thanks it's ok I've seen a couple of these projects here and there
The dash trim kit really looks nice, I think I'm going to buy it somedayDid you took the vinyl one on eBay ?
I'll try to post the pics of my carputer install tomorrow ! I've used black carpet to cover mine and it came out pretty well tooalso it's "invisible"
My Corolla Computer
wow, that really looks nice!
Is this where the witty comment goes?97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
ACleanSC4 - Yea, it's an auxiliary battery (2nd batt). I just used a surepower isolator, which essentially allows the alternator to charge both my main and aux battery at the same time while keeping the two systems separate. I run all my accessories (ie, amp & comp) off the optima (it's the yellowtop D51). I can post a pic of the isolator tomorrow.
CapitaineFritz - actually, my dash is all painted. I tried doing the whole vinyl thing and it was quite the hassle. One thing you should note is that the middle part with the A/C controls is essentially just a sticker. People said they used heat to help get the vinyl on, but I melted that part since it's really thin. (luckily, you can buy a replacement for that section, which really is just a thick sticker, hehe) So I just used some rustoleum silver spray on all the parts instead of the vinyl thing. It's workin fine![]()
My Install
thanx stealth!
ACleanSC4, here's a pic of the isolator I used in my setup, it's a surepower 9523AD, 95 amp max I believe:
I put the top of a cut up 1-liter soda bottle to shield it from stray water![]()
My Install
Very nice. I have the same car, just the dark grey color. I really love your work. I am planning my case and I like what you did. Keep up the work and enjoy it!![]()
