Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 82
Thread: 2003 Corolla S Install (lotta pics)
  1. #21
    Registered User Dudes99's Avatar
    Dec 2004
    Norfolk, Va
    Quote Originally Posted by scott_fx
    i think it would look better if the gps and wifi were hidden
    edit: how about mounting it to the underside of the rear shelf?
    That wireless router has a removable antenna right? If so got hit your local rat shack for a coax cable and then hide the router and run the new coax/ant somewhere outsite the car(trunk lid, clip on, etc...)
    Oh and GREAT JOB!
  2. #22
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    NICE - I want to build a box like that for both sides of my trunk. One side will be the sub - the other, the carputer.
  3. #23
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    nice car, cool box.
  4. #24
    Constant Bitrate bulgogi777's Avatar
    Jun 2004
    NW FL
    thanx for the comments guys~! I was actually thinking about getting one of those black magnetically mounted antennas, and putting it on the outsite... anyone had any good experiences with those?
    90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
    My Install
  5. #25
    Jun 2004
    NW FL
    oh, and yea I was thinking about building one for the other side... although CapitaineFritz is doing one via fiberglassing... I think I'll wait to see how his project turns out, and try it that way... rather than start with plywood/mdf
    My Install
  6. #26
    Low Bitrate BrUTaL's Avatar
    Dec 2003
    Guayaquil - Ecuador
    bulgogi777
    Great work, I can see that you put a lot of time and effort. Nice to see another Corolla, better to say, more Corolla owners with this idea. When I joined this site and search for corolla...the results were 0...
    However, I currently live in Ecuador (South America) and my Corolla is from Venezuela, few things are different. I am about 95% done with my project, I will be posting all my project this weekend.
    Once again, great install...congratulations, I like your project a lot. I just love the way you put the screen, it looks very nice
    By the way, was it difficult to replace the dash light with the blue leds?
    Is that keyboard wireless or wired?
    How is Centrafuse? Is that the only front end you use? I am currently using MediaCar, however I am planning to test some new ones that came out so let me know about centrafuse.
    And last, great install!
    Progress = 50%
    CarPC: INTEL Desktop Board D201GLY | 20GB 2.5" HD | 1GB DDR PC5300 | Lilliput 7" VGA TS | OPUS Solution 150W DC-DC ATX | Stowaway Universal Bluetooth Keyboard | Reverse Camera | Windows XP SP2
  7. #27
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Very nice just one question. Where is the fuse on the back battery?
  8. #28
    Jun 2004
    NW FL
    Hey Brutal, thanx for the comments~! Yea, there's only a few of us corolla guys here on this board... but it seems to be growing
    The dash lights are a bit of a pain to switch out. I bought some blue leds that have a forward voltage of 3.2 ~ 3.8, which is typical of leds that you can buy. So you have to put a resistor in line, so that it can operate off of the 12v accessory line. If you look at the bulb holders for the lights, you can see that they're held in via a small wire that wraps around and contacts the holder to get the voltage. So I just used a very small gauge wire to emulate the wrap around and soldered the led and resistor to the wire. The only thing is that since the leds are directional, it's kinda hard to get an even light across... but it's decent. Now, the really hard part was behind the A/C controls. There is basically two bulb sockets for that part, and I lost one so I could only use 3 leds behind that part. I actually taped foil all in that white A/C control holder to reflect the light around better... but it's a little uneven... it doesn't look too bad though, I actually think it's decent. (but you should probably use 6 leds with both sockets if you do it) It's 3 leds per socket each in series and a smaller resistor than the single led scenario... phew! long winded answer, but I think you get the idea. Meticulous pain
    The keyboard is a part of the gyration wireless combo (mouse/keyboard), and that blue box thing near my wifi antenna is the receiver. It fits perfectly into the glove box. The reason it stays up like that is because there are these tabs that stick out the top of the keyboard... and I just cut two slots in the back of the glove box, so it sits in there nice and tidy
    As far as the frontend, I originally used frodoplayer, but switched because I liked the integration that centrafuse has a little better. It might be a toss up between the two new versions though... I'll probably use whichever one comes out first - v1.3 or take 4.
    Anyways, hope that helps, we corollans got to stick together, lol
    My Install
  9. #29
    Jun 2004
    NW FL
    SickVette, There is a 50A fuse for the main power line is in the engine compartment... you can see it in the pic where I point out my isolator. I know it should probably be as close to the battery as possible, but I'd already wired that 4 gauge from my first install attempt in a different configuration. So I just left it up there... That wire basically goes to the distribution box which has 3, 4G inputs and 2 fused 8G outputs. The fused outputs are my amp and computer. I use 2 of the inputs as a "connector" for my battery cable (the one from the engine compartment to my optima).
    My Install
  10. #30
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    beautiful
    DICE Los Angeles
  1. Audi A4 Dash Install Pics
    By surfer6262 in forum General Hardware Discussion
    Last Post: 08-07-2002, 04:14 PM
  2. Install pics
    By anothamp3frk in forum General MP3Car Discussion
    Last Post: 07-04-2002, 04:52 PM
  3. Some pics of install
    By ppgt94 in forum General MP3Car Discussion
    Last Post: 04-04-2002, 12:21 PM
  4. MP3 player install pics in a 99 Vette
    By cjones in forum General Hardware Discussion
    Last Post: 01-09-2002, 09:26 AM
  5. New install pics
    Last Post: 08-13-2001, 01:25 PM
