Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: 2005 Subaru Forester XT dual screens Dialup BEWARE
  1. #31
    Sep 2005
    One question: it looks like the installed flip-out screen isn't flat with the dash. Is this true? Did you have to cut around the dash a bit?
  2. #32
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    That is correct. It sticks out about 1/2-3/4 of an inch in front of the dash. And in my car I had to cut a tiny bit to make it fit. It was just a tiny bit to wide.
  3. #33
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    I understand how the 2 video positions can be set in xml / ini files etc .... to get the proper placement, but I just was wondering how the touchscreen software works.
    Do you have to run 2 different TS --> mouse apps ???
    can you elaborate on this .... I'm sure it's simple, but I'm curious..
    Don
  4. #34
    Minneapolis, MN
    The TS driver/software will allow for multiple TS's. You just have to set up the orientation, and select which one is TS1 and TS2. It's very easy!
  5. #35
    Variable Bitrate daclothe's Avatar
    Dec 2004
    new balance 991's - great choice!
  6. #36
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    How's the 9855 working for you? Is it easy to see the screen text in the daytime? Any hitches with it?
  7. #37
    Minneapolis, MN
    I like it. The screen is very visable except when the sun is setting, and directly shining on it. THen it can be a bit tough to read. The iTouch or whatever it's called takes a bit of time to get used to, but after you do it's pretty simple.
  8. #38
    Jul 2006
    Quote Originally Posted by daclothe
    LOL, they are nice. I might be buying the 992's in the future.
    On another note. What part number was the Nav Gauge Pod, and you said you bought it for $120?
  9. #39
    Jun 2006
    NorCal
    Quote Originally Posted by sinhcredible View Post
    I recently bought the gauge pack housing here, for $60 + shipping. The part number is H0010SA950ML. If you give the part number to your local subaru dealership, they can also order it for you.
  10. #40
    Newbie JpLelko's Avatar
    Oct 2006
    Elk Grove, CA
    Awesome setup!! i was wondering, how you like your JL XR650-CSi componet speakers? were they hard to set up and tune? i am planing on running those componet speakers with the same JL 300/4 amp as well and i was wondering how the sound quality was on it. well props on the awesome setup!! Auf Weidersehen!
    Progress:
    Planning [XXXXXXXXX-] - 90%
    Building [XX--------] - 20%
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 11:45 AM
