Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: '98 Corvette Indy Pace Car-Puter
  1. #31
    Jul 2005
    Quote Originally Posted by maha
    hi.. very nice work! nice car too!
    i also have an inspiron notebook but want to use it with the m1-atx.. any idea how this could work?
    especially, i want it to shut down when the ignition gets off.. m1-atx gives the signal but i dont know where i could put it in the notebook.. does it have an atx-port?
    thx!
    I didn't see any way to use a M1-ATX power supply for computer power.... The power requirements for the notebook are just too different. I chose to use a docking station which gave me access to the power button in the dock which could be used to shut it down, but you'd need a delay-relay as it is momentary only.....
    The other thing you might consider is just letting ut shut down from power management.... That's what I use "just in case" I forget to shut it down myself. Once my ignition is off, the notebook switches to notebook battery.... I have power management set to shut down when battery power reaches 75% for everyday driving..... If I don't shut it down, it simply shuts down by itself....
    Fred!
  2. #32
    Jun 2005
    I understand you wrote your own software. Is it available for other people to use? It looks tight!
  3. #33
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    Swwwwweeeeeeet car dude.
  4. #34
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    haha Awesome... Good work my man.
  5. #35
    Jul 2005
    Quote Originally Posted by dougiefresh
    I'm really just using the software as a "Front-End" to launch my apps.... I just wasn't that crazy apout an integrated app..... I wrote it mainly to make everything accessible using a touchscreen, PLUS, it does control my "specialty" stuff, i.e., the strobe controller, radio antenna, amps, etc....
    I'd be more than happy to share any of the code... It might be helpful if someone was going to use a serial relay board to control anything, but it is kind of "specialized" to this application.... It was written in VB....
    Thanks for the comments!
    Fred!
    1998 Corvette Indy Pace Car
    My Install: http://www.mp3car.com/vbulletin/showthread.php?t=53837
  6. #36
    Low Bitrate cavramair's Avatar
    Aug 2003
    Ohio
    The best install I have seen on these boards, or anywhere!
    -Drew Taylor
    2000 Grand Am GT PC
  7. #37
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    where is the did you get the relay controller from? and how did you wire the strobe controller to control pattern by the relay board??
  8. #38
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    I was wondering the same thing - where did you get the relay controller from? There's a few different ones I've seen around the net - which one did you go with?
    Also - email sent about code
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
  9. #39
    May 2003
    Florida
    i really want to know how you can control the flash pattern with the Serial Relay Board ?
  10. #40
    Jul 2005
    Quote Originally Posted by kickercivic1
    I'm using a R85-PRO from controlanything.com. Take a look at the wiring diagram I posted.... I'm using a Whelen strobe Controller which has 3 wires you switch to control pattern... Depending on which wires you switch, you select a different pattern.... I simply use 2 relays on the serial board as pattern relays with the 3rd wire as common.... The software simply closes the relay or relays needed to choose the pattern.....
    I have the R85-PRO on USB, and you just send it ascii characters to tell it what to do.....
    Hope that helps!!
    Fred!
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. so my car puter died today...
    By spyhunter in forum General Hardware Discussion
    Last Post: 10-07-2003, 08:47 AM
  4. Hardware for in car puter
    By mikewrt in forum Newbie
    Last Post: 09-13-2003, 12:26 PM
  5. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
