Yeah it did. I had many other devices hooked up before and I figured it was just time for an oil change. It's probably cause the amount of amps being sucked out of the main power wire is too much and the car computer does not recognize it. Probably need to reprogram the cars computer to allow more output. Is your Satellite radio hooked up off your main power wire or off the battery?
The sat runs off the head units CD changer controls. It doesn't need external power. Are you sure you're looking at the SRS light and not the Check Engine light. Cause if it does infact say SRS, that (unfortunately) has nothing to do with your oil. That's your airbags.
I have two fears, 1) They won't go off when I'd like them to. 2) They'll go off sometime before I'd like them to.
Sorry man my SRS light never lit up. I tried resetting my engine light though and it came back on. I check my oil and other engine parts and they seem to be OK. It must be from the electrical mods. I don't care too much as long as nothing is wrong with the car. Also I took the buttons of the VGA off the bottom. Power comes on the VGA on start up, I don't have any other inputs and it looks much cleaner. I plan on taking the infrared light and mounting it so I can use the controller to the VGA.
can't see the pics. please fix the link.
Yeah fix the links so we can see. Wanna see what other 6th gen accord owners have done with their car pcs. I got a 2000 V6 Accord Coupe, finished carpc completely with 7" lilliput touchscreen about two weeks ago when motherboard died after I installed my new amp two days ago. Sucks but got it RMAed from where I bought it from. Ill post some pics of mine when i can get a digital camera.
i wanna see the pics but the links are dead for me too.
Updated Pictures
Now about 95% done. Put the boards on trays and took buttons off screen.
about the SRS light, it comes on if
A. you pulled the fuse for the airbags
B. voltage drops and is insufficient for your system (probably the case)
C........legit SRS failure....or circuit issues...etc
I had B happen because my alternator went. My light would go on and off at random. I replaced the alternator the other day, it hasnt gone on yet (it was going on daily as i'd accelerate).
nice car and a nice install dude
wow... your car is tight Inside and Out - Congrats and two thumbs up!! :D
