Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: BMW Laptop Install
  1. #11
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by Enforcer
    Show it pictures of another laptop with it's cover off
    Make sure it has USB ports as built in floppy drives can cause problems with the hard drives this way, they tend not to work as well.
    Terran
  2. #12
    Oct 2004
    NY
    & he didn't get it!
  3. #13
    Newbie JKnoxxville's Avatar
    Jun 2005
    Los Angeles, CA
    Quote Originally Posted by Hark
    I thought the Xenarc resolution was 800x480? You're not using PowerStrip to get the native resolution?
    As far as the hissing, maybe the AMP is powered up all the time, even when the PC isn't? What configuration is the sound system? Are you using a shutdown controller?
    Nice screen molding, looks good. Did you do this yourself?
    No i'm not using powerstrip, right now im using 1024x768 reoslution, I adjusted the Fonts to be bigger. The hissing was solved, I went to a local stereo shop and bought a filter for one of the RCA connections. I just shutdown the laptop in a normal way that you would on a desktop. Turning it on is not too bad becoz the laptop has an ext. switch on the side. About the screen molding i had it done via fiberglass guys near where i live. The screen molding is configured to hold the whole xenarc screen without taking it apart, coz i want to save the warranty. Big problem though when im driving in the day i can't really see a thing on the screen coz of the fre@kn glare.. What can u suggest?
    BMW 330ci
    CAR PC: Fujitsu B2620 Laptop (mounted under driver seat)
    OS: WINDOWS XP HOME SP1
    Screen: 7" Xenarc TSV
    TV/FM TUNER: KWORLD USB
    GPS: I-GUIDANCE WITH ROYALTEK GPS RECEIVER
    http://www.mp3car.com/vbulletin/showthread.php?t=56187[/URL] ER
  4. #14
    Jun 2005
    Los Angeles, CA
    Quote Originally Posted by CapitaineFritz
    You have pics of the car?
    Here's some pics of the car:
    BMW 330ci
  5. #15
    Jun 2005
    Los Angeles, CA
    Quote Originally Posted by wei2cool
    how do you turn on the laptop???
    there's a switch in the side of the laptop so i dont have to open the top.
    BMW 330ci
  6. #16
    Jan 2003
    Quote Originally Posted by JKnoxxville
    Not a 100% on how you do this but you may want to consider a carnetix.... it should give you a stable supply and an on off function. That been said it is designed for a desktop so you may have to modify it some how.
    Terran
  7. #17
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    It would look a lot better (IMO) if you used the native resolution of 800x480 - anything else will look fuzzy/distorted. Also, you might want to use a SDC instead of a desktop power supply. I use a uSDC20D and just have it go to standby when the ACC is off - it comes back up in 1 sec when the ACC is back on.
    As for the glare, window tinting helps, but until the newer/brighter Xenarcs come out, we're SOL for daytime viewing.
  8. #18
    Jun 2005
    Los Angeles, CA
    Damn, how can connect my laptop mainboard to the USDC20D? ive No idea whatsoever..
    BMW 330ci
  1. Replies: 2
    Last Post: 07-01-2005, 05:20 PM
  2. Replies: 6
    Last Post: 06-14-2005, 04:43 AM
  3. FS: Laptop and Touchscreen.
    By emailthis1 in forum Classified Archive
    Last Post: 06-13-2005, 12:51 AM
  4. Would it be safe to use my laptop?
    By Keyser in forum Newbie
    Last Post: 02-06-2005, 09:36 AM
  5. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 10:52 PM
