Results 21 to 30 of 36
Thread: 2002 Mitsi Evo 7, Voom case.
  1. #21
    Jul 2005
    NZ
    Updated
  2. #22
    Jun 2005
    very nice job! how did you make the lcd mount?
    and was it hard to move the hvac controls?
  3. #23
    Jul 2005
    NZ
    Just made the mount from cardboard and when it was right made it from light steel strap. It uses the original stereo mount holes.
    HVAC needed the bottom of the trim cut to fit there, all the wires reached with no problems.
  4. #24
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    very nice car. i'm partial though since i have the evo vii front end conversion
  5. #25
    Jun 2005
    is the plastic piece that surrounds the lcd stock?
    if so, i wonder if it'll fit in place of the plastic piece on my evo8 since the outline is identical... my piece only has one din for the radio and the hvac controls are integrated into it. i've included pictures... does it look like the clips are in the same spot?
  6. #26
    Nov 2005
    Los Angeles, Ca
    the one he has will fit in our cars. read this :
    http://forums.evolutionm.net/showthread.php?t=135739&
    http://forums.evolutionm.net/showthr...0&page=1&pp=15
    http://forums.evolutionm.net/showthr...3&page=1&pp=15
    also, i have an extra hvac piece if you want to try cutting it up so you don't ruin yours. let me know if you want it.
  7. #27
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    nice car and nice install
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  8. #28
    Jun 2005
    blacklancer: thanks, actually i remember reading that post a while ago... guess i asked him back in september if he was successful in moving the hvac controls, too, but he didn't answer. thanks for the offer of the hvac piece, i'll let you know if i want to give it a go. still weighing my options... thinking about the mtsvo-sc but people seem to be having problems with it.
  9. #29
    Jul 2005
    NZ
    You will need to tilt the screen like I have. I did have it mounted flush to the trim but it reflected way to much, so I made up the spacer.
  10. #30
    Jun 2005
    thanks. it looks like it's just about vertical, is that right?
  1. What's with the sudden flood of newbs?
    By ShinkunoNamida in forum Off Topic
    Last Post: 03-29-2007, 01:43 PM
  2. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  3. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 04:50 PM
  4. To case or not to case?
    By dummptyhummpty in forum General Hardware Discussion
    Last Post: 04-08-2004, 06:19 PM
  5. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 09:42 PM
